Crack was working well but after upgrade to speedball
vpcrack · 5471
Offline vpcrack
help please, yes after upgrade to speedball the capacitor and the resistor are burning with smoke!!
i don't believe I did anything wrong with the upgrade.
Please help as I am a complete noob here.
Reply #1 on: March 26, 2014, 11:09:13 PM
The place to start here is with the power off and make the resistance checks.  Post any resistances that are +/- 15% out of spec.
Then see if you can determine what resistor burned.  You might be able to measure its resistance in the circuit.  If not you will need to unsolder one end to measure it.  It depends on which it is.  Post which it is first and one of the Bottleheads more familiar with the C4S circuit can answer whether you need to lift one lead.
Hang in there, these things get solved if you stick with it and answer the questions asked.
Reply #2 on: March 27, 2014, 05:38:47 AM
Unfortunately it is most likely that something was done wrong to create that situation. First carefully check all of your connections against the photos and instructions in the manual. The most likely thing is that a wire is connected to the wrong terminal somewhere, or a bare wire is touching something that it should not touch.  Next redo the resistance measurements and post any that are not within the specification of the manual. Don't turn it on again until you have done those two steps.
Offline vpcrack
Reply #3 on: March 27, 2014, 12:17:44 PM
The thing is I haven't even got to the resistance check part yet. I only got to the "turn on the power"part that smoke started coming out of the amp. It appears that the resistor and the capacitor were so hot that it even melt the solder. Anyhow I will check and recheck the wiring and the soldering again. Please be patient with me as I'm really new to this hobby.
Reply #4 on: March 27, 2014, 02:06:58 PM
Quote
Actually I am suggesting to go back to the original manual for the Crack and redo those resistance checks. That may help to point out where the short is that is burning up the resistor.
Offline vpcrack
Reply #5 on: March 27, 2014, 03:57:05 PM
Is it normal that the resistor that is soldered to the 21U and 15U pins is burning hot( to the point of burning me when I inadvertently touch it)?
And yes I will go back to the crack manual to check  the resistances.
Reply #6 on: March 27, 2014, 05:17:25 PM
This would indicate a short in the circuit.
When I have seen repairs that began with these symptoms, it was a loose connection that connected two adjacent terminals right by the burned resistor in question.  You would want to look at terminals 14, 15, and 16.  If any adjacent pair has metal between them allowing them to touch, that would cause a short and the entire power supply voltage would be cooked of by the resistor you are referring to.
Since the other 270 Ohm resistor isn't exhibiting this behavior, we are able to narrow down the source of the issue quite specifically.  (If it was a short in the upgrade, both resistors would be burning hot)
Offline vpcrack
Reply #7 on: March 27, 2014, 05:38:32 PM
I'm giving up.
I can't even do the resistance check for the simple fact that those 2 resistors are so hot that they melt away the solder at the terminals that they are attached to. And yes I checked all soldering, all connections. And I believe they are good.
Reply #8 on: March 27, 2014, 05:41:07 PM
But the amp shouldn't be powered up for the resistance checks.
Offline vpcrack
Reply #9 on: March 27, 2014, 05:44:40 PM
Paul, yes indeed it's both resistors that are hot. I have very limited knowledge in electronics AND electricity. So now what are my options? Please help!
That I didn't know!
Reply #10 on: March 27, 2014, 05:51:01 PM
I'd suggest going back to the basic Crack manual and go through the entire resistance check procedure from the start. It starts on page 37 and mentions that it is intended to be a way to check the amp out before you plug it in and apply AC voltage to the amp. That gives you a way to test for the correct connection of the parts without risking further damage.
Offline vpcrack
Reply #11 on: March 27, 2014, 06:41:17 PM
Yes Doc, the resistance checks are as followed:
terminal1     no reading
             2     no reading
             3     0
             4     no reading
             5     no reading
             6     2.48
             7     0
             8     0
             9     0
            10    2.48
            12    0
            13    no reading
            14    0
            20    0
            22    0
            B3    0
            B6    no reading
            Rca Jacks: ground lug   0
                             center pins   no reading
Am I missing something?
Those numbers don't look good, am I right?
Reply #12 on: March 28, 2014, 09:40:52 AM
             7     0
             9     0
That is not good.
Remove the large PC board (heat each joint and pop the wire out), then run the amp without the 6080 tube and without the big PC board.
Offline DenverDude
Reply #13 on: March 28, 2014, 11:54:50 AM
Hang in there, vpcrack. Paul and Doc B. are EXTREMELY helpful and walked me through a few speedbumps I had and all is working great now. Just give them answers to their questions and have patience and you will get this sorted out. It is totally worth it.
Offline vpcrack
Reply #14 on: April 01, 2014, 06:36:40 PM
             7     0
             9     0
That is not good.
OK, so I removed the large PC board, removed the 6080 tube and hook up the amp to the power and turn it on. The capacitors and the resistors are cool to the touch.  What's next now?
