Hi guys!
Ok...Now I really have to step in here and poke some fun. A "redneck bucket sub?" The description mentions Bible passages mixed in with 4:20 references? Umm. ok? My BS-o-meter is pegged at "11"
Yet every time you point a finger there are 4 pointing back...(and anyone who knows me personally knows that I do "get the joke" of the bucket sub.)
I happen to make "Thrashers." They sound fantastic. Now, I can't make your decisions for you, but please folks, use the bucket sub with Thrashers, not Orcas...
http://www.blumensteinaudio.com/on-sale/As a total counterpoint to the price point of the bucket sub experiment, recently I upgraded our system to "Deluxe Dungeness" with the same 25 watt Dayton amp but built with all 3/4 inch chocolate bamboo in my reference Deluxe Orca system (driven by Paramounts) and I did notice a slight benefit to transients, bass size, and overall "disappearing act" of either a single or a pair of this 3/4in sub construction. Now we are only talking about a roughly 5-10% "total" improvement (which is still very important to me as a designer.). Still though, along with several other improvements to the demo rig lately, and more to come, the deluxe demo system we are running right now is something we are really proud of. Its been sounding really and truly musical lately.
The recent improvement with Deluxe was attained without any gain, tuning, or crossover changes from the normal Dungeness. And of course there won't be a measurable difference, and I'm cool with that. Considering how refined the construction and materials quality of a 1/2 inch dungeness already is, I was surprised to hear ANY benefit from the thicker/different cabinet wood. Yet, aesthetically, the sound difference is there.
There's no way I'll be able to measure it other than to tell you to knock (with your hand) the 1/2 inch Dungeness cabinet, and then knock the 3/4inch Dungeness cabinet and you'll hear a little less resonance and different character of resonance with the Deluxe construction. And it costs more money.
I actually used to make a subwoofer for an older model of Orcas which used the same 8" peerless woofer Ed mentioned for the bucket sub. Its a pretty good driver. I tried that driver in both sealed and BR and greatly prefer the BR. Ultimately I went for something that is a little more "chill" sounding which is the 6.5 inch woofer we are using now. That 8" peerless ultimately sounded a little out of control down into the ultra lows to my ears, or just something not quite right but hard to put my finger on. It might have been a problem with the cabinets I was trying it in. Maybe I should have had the thing in a bucket? Who knows?
Still, my answer for someone seeking more dynamics from the bass augmentation of their Orcas would probably be (as you might guess) multiple Dungeness. We have folks sending in RTA's of their systems in room w/ single or double Dungeness showing that they are very well behaved in real rooms down into the mid 30's and that psyco-acoustically it all integrates well in either carpeted or hardwood environments.
But back to te topic of a DIY big subs - I'd recommend a pretty wide range of X/O's to experiment with - anywhere between 75-90hz (depending upon the subwoofer and X/O slope). In terms of X/O slope range, anything between 12 and 48db could be the ticket. It all depends on the driver and cabinet character. I do prefer plate amps for my production models because they are cheap and easy to adjust and sound great if you get the right one for your system.
Other subs? The Dayton Audio reference 8" is a good driver. As is the Eminence Lab 12. Both need large cabinets. the Fostex 8" woofer is also good and I've built a few. those get down to the 20's. Very expensive driver, and a long lead time though. It was not as transparent/integrated as the 6.5 we are using now, and it just had unnecessary frequency response for most peoples' systems. But that's what DIY is for, right?
Once I tried 4- 15" woofers with the Orcas. This was nice, very natural and dynamic, but the low frequency cutoff began around 60 hz which just wasn't low enough, and the stiff suspension systems in the pro audio drivers I was using didn't "wake up" at the same time that the Orcas did, volume wise. So I tweaked everything out to line up at the Orcas' maximum volume capability with the Paramounts. This ended up being pretty nice overall, but again, still just didn't go low enough. Over time, I've concluded that I really need my bass to go down honestly into the mid 30's or I just can't connect with the music the way I want to.
Some of the best bass I've heard with the Orcas was hooking them up in my buddy Pete Riggle's room. The Orcas were standing in the place of his 3 way horn system which normally goes down to around 100hz. Those typically then get augmented by a true -3db at 20hz, 30 ft long horn loaded subwoofer (with a mouth so big you could drive a car into it). We adjusted the sub for the phase of the Orcas and then after about 10 minutes of delicately adjusting gain and crossover frequency, wowee! It really worked. Very surprising that it mated so well. Super subtle yet powerful. If you've got the space in your attic...this system did pipe organ like you wouldn't believe.
Now if you really wanted to go crazy, then just get a DEQ-X or equivalent. You can tailor the system with infinite precision. A really good digital EQ and X/O, I don't care what anyone says, is both expensive and transparent. Dan's mega system on the other hand uses gentler slope tube crossovers and these also sound very nice indeed. Overall I might prefer the tube X/O's because...well, I dunno. YMMV.
Yesterday I had a local pickup of a deluxe center channel pair/double dungeness order from the shop. This was the first Deluxe CC/double Dungeness system I'd heard in a while and it was better than I'd remembered. We have another order like this to send out next week and then I'll be making a system just like it for our demo space.
Overall, I guess my message is that if one is looking to out-perform the Dungeness, it might be wise to either purchase multiples, or just take a much higher end approach entirely.
(and on another note...man, the bucket sub totally cracked me up! Took me right back to my warm and fuzzy memories of college daze of audio DIYing. Thanks for posting!)
Cheers!
-Clark
