Loud Screech starting up
smallmany · 1887
Offline smallmany
on: March 29, 2014, 07:34:56 AM
I leave my headphones plugged when I start my amp, and I noticed it makes a sound like a nail is being scratched across a blackboard.
Is this normal
Offline smallmany
Reply #1 on: March 29, 2014, 07:38:52 AM
Amp is not connected to source and at quarter turn on the pot when its fired up.
Reply #2 on: March 29, 2014, 08:49:31 AM
Does this only happen when it warms up?
Some tubes will sputter just a little bit while warming up, this isn't particularly abnormal.
Offline kscwuzhere
Reply #3 on: March 29, 2014, 01:06:07 PM
I used to have an extremely loud popping/crackle sound when plugging in my headphones and solved the issue by checking the grounding path and making sure that I had no cold solder joints. After I found which ones did, I re-soldered and the crack was back to normal. There's a sticky thread about the Crack's grounding path, I'd check that out.
