Modifications to run e80cc/12bh7a/5687 for Crack+Speedball
kscwuzhere · 133675
Reply #105 on: May 14, 2014, 06:24:37 AM
Would installing these LEDS in series with a switch or in parallel with a switch allow us to achieve the correct plate voltage? Otherwise we'll just have to chance it with some LEDs.
Paralleling diodes doesn't really word, you have to have just one or the other.
Reply #107 on: May 14, 2014, 04:18:43 PM
The first one is a surface mount part, and you don't want to deal with that.
I'd suggest just starting with one pair, I haven't yet run into LED's causing issues in this situation unless the circuit is very, very sensitive.
Offline kscwuzhere
Reply #108 on: May 14, 2014, 06:43:52 PM
Alrighty, I'll get those LEDs and toggle switches ordered and update ASAP! Thanks PB
Offline onelivewire
Reply #109 on: May 15, 2014, 03:09:58 PM
Can't wait! You guys really kick ass for providing this level of customer interaction. I can wholeheartedly say that I wish all business could make themselves a part of the community with such social outreach. I can't say thank you enough!
Offline kscwuzhere
Reply #110 on: May 19, 2014, 02:20:09 PM
Once I get this mod done for the 5687, would I be able to roll the 7119's with the crack too?
Reply #111 on: May 20, 2014, 04:59:38 AM
Yes.
Offline kscwuzhere
Reply #112 on: May 20, 2014, 10:10:01 AM
Awesome! Onelivewire and I are gonna give this thing a shot once all the parts come in and I'll update the thread accordingly.
Offline kscwuzhere
Reply #113 on: May 21, 2014, 05:02:43 PM
Switches/biases have been installed, just waiting for the proper resistors and tubes to come in now! Exciting stuff!
Offline JamieMcC
Reply #114 on: May 22, 2014, 05:34:28 AM
Ok well I find myself liking the two 12bh7's that arrived in the post this morning I have been listening to them on the 12au7 setting but am mindful of how well the e80cc sonics improved with the resistor mod once better matched so once again interested in following progress here.   :)
Loon
Reply #115 on: May 22, 2014, 05:58:31 PM
I thought I would join the club and add a three way switch to SB allowing me to select between three resistance values for E80CC 12AU7 and 12BH7.
I checked actual vales for resistance before installing speedball and they came to the expected values.  I inserted both an E80CC and a 12AU7 (don't have a 12BH7 yet) and measured voltages of between 75 and 80 on the correct switch settings.
Listening on the E80CC everything is sweet (switch position off).  On the other two settings there is a horrible hum in both channels that never varies despite changing volume via Submissive or volume pot.
Did I mess up design, implementation or do I have a dodgy part?
« Last Edit: May 22, 2014, 06:06:40 PM by Loon »
Reply #116 on: May 22, 2014, 06:00:57 PM
Is this with the E80CC or the tubes that those positions are supposed to feed?
This is part of the risk of switching R1's.
Loon
Reply #117 on: May 22, 2014, 06:15:54 PM
1.  Tested with 12AU7
2.  Is the hum part of the risk of this mod?  If so, what causes it and why isn't everyone reporting the hum?  If not, what exactly is the risk you are referring to?
For the record, I will take risks all day if I can learn from them, especially with a bargain amp like the Crack.
Reply #118 on: May 22, 2014, 06:37:47 PM
Yes
Not everybody is going to build this the same way.  (There's no manual)
Loon
Reply #119 on: May 22, 2014, 06:46:24 PM
Paul, do you and the rest of the staff support modding in our community?
Is there anyone else reading this who is willing to help an idiot and a Loser (ie, me) trouble shoot?
For instance, what are the common causes of hum, how do you determine the cause and how do you eliminate it?
« Last Edit: May 22, 2014, 06:50:47 PM by Loon »
