Modifications to run e80cc/12bh7a/5687 for Crack+Speedball
kscwuzhere · 115710
Offline kscwuzhere
Hey so I currently have a crack with speedball driving my Hd650s. My current output tube is the Chatham/Tung-sol 5998 and the driver tube is the Tungsram e80cc. I read somewhere that there are some possible circuit changes you can make to run these two tubes optimally and I was just wondering what these changes were? Do I need to replace or add any additional resistors? Thank you bottlehead community!
« Last Edit: May 20, 2014, 10:10:39 AM by kscwuzhere »
Reply #1 on: March 29, 2014, 10:07:38 AM
What voltages do you get at T1 and T5 with the E80CC?
Offline kscwuzhere
Reply #2 on: March 29, 2014, 12:50:54 PM
Terminal 1: 130V
Terminal 5: 121V
Reply #3 on: March 29, 2014, 04:00:59 PM
Yeah, that's not really so great.
Try replacing the 237 R1 resistors with 470 Ohm resistors to see if the voltage bumps down between 55 and 85V.
Offline xcoolhandx
Reply #4 on: March 29, 2014, 04:28:08 PM
wouldn't this be a permanent change and how would this affect the other tube rolling ?
Offline kscwuzhere
Reply #5 on: March 29, 2014, 05:50:16 PM
So I went ahead and ordered a bunch of 470 ohm resistors, hopefully that'll do the trick!
Reply #6 on: March 30, 2014, 06:26:16 AM
Yes, it would be a permanent change.  Yes, it won't be ideal for other tubes.
Offline JamieMcC
Reply #7 on: March 30, 2014, 06:55:28 AM
Please post some feed back here on how you get on with the resistor swap, I tend to favour the E80cc also and am very tempted to go down the same path.
Cheers
Offline xcoolhandx
Reply #8 on: March 30, 2014, 07:22:44 AM
what could happen if I won't change resistors....would I need one of this attached to Crack
Reply #9 on: March 30, 2014, 07:43:49 AM
You'll throw off the operation of the 6080.  The results won't be great (IMO) with both the Speedball and the stock kit.
Offline xcoolhandx
Reply #10 on: March 30, 2014, 08:16:42 AM
Thanks Caucasian
Offline kscwuzhere
Reply #11 on: March 30, 2014, 10:34:02 AM
Cheers
I'll make sure to update this thread with the voltage changes after I swap the resistors.
By switching the resistors and running the tubes optimally, what audible differences would result?
edit: Also, I ended up getting the 1/4W 470ohm 1% metal film resistor, would this suffice for the swap?
« Last Edit: March 30, 2014, 11:31:39 AM by kscwuzhere »
Offline kscwuzhere
Reply #13 on: March 31, 2014, 11:40:41 AM
So I ordered the wrong resistor? Are 1/4W 470 ohm resistors fine or should I order something else?
Reply #14 on: March 31, 2014, 12:23:48 PM
1/4 Watt will work fine, they will just be physically kind of large.
