Resistance Check Failure [solved]
Rhok · 9055
Offline Rhok
Reply #30 on: April 11, 2014, 05:37:58 PM
Hmm, I grabbed a AAA rechargable battery and got a 1.321  V DC reading, so that would indicate that it should be reading DC voltage properly, what now?
Reply #31 on: April 11, 2014, 07:06:12 PM
OK, this is a bit of a pain, but try disconnecting the 270 ohm resistor and the positive terminal of the 220 uF capacitor from terminal 21 and then measure the DC voltage at terminal 21 the same way as before, red to 21, black to 12. That will help determine if the rectifiers are bad, or if they are working Ok and there is a short to ground in the circuit somewhere after the rectifiers.
By the way, I have had meters that worked OK on lower scales but didn't work on the highest voltage scale. If you had it set to a lower scale when you checked the battery you might want to measure that battery one more time on the 400V scale. It won't be as accurate, but you should see at least 1V.
Reply #32 on: April 12, 2014, 04:44:31 AM
How about posting a picture of the right and left sides of the terminal strip where the diodes are.  We want to verify that the diodes are oriented properly.
Offline Rhok
Reply #33 on: April 12, 2014, 05:24:07 AM
Doc, I will attempt your recommendation after Grainger reviews my pictures, additionally, while having my multimeter set to 400 range, testing the same battery yielded these results: 001.3 V DC.
Grainger, here are the pictures you requested: http://i752.photobucket.com/albums/xx165/mikemathis3/IMG_0719_zps273125bf.jpg & http://i752.photobucket.com/albums/xx165/mikemathis3/IMG_0718_zps0b94f959.jpg
Reply #34 on: April 12, 2014, 05:40:03 AM
They are all correct.  I also see the caps are oriented properly.
I'm with Dan, try reading the DC as he says and then directly.  Try measuring DC from (always the black lead) terminal 21 to (always the red lead) terminal 20.
Also, I'm not positive that the AC feed is solid.  Try measuring from terminal 18 to terminal 19.
Your transformer seems to work properly.  The circuit just totally dead somewhere and we are right on top of it.  It will come to light soon.  Hang in there.
Reply #35 on: April 12, 2014, 05:55:49 AM
I think I see a loose wire.
Offline Rhok
Reply #36 on: April 12, 2014, 06:29:14 AM
You're the freaking man Paul! Excellent attention to detail, it was just making connection with the insulation instead of the wire. As soon as I saw what you saw I removed the solder from that terminal, readjusted the wires, and re soldered, we may be in business now I'm going to do another voltage check.
21: 205.5 V DC
Additionally - LEDs glow!
Will post more momentarily.
Offline Rhok
Reply #37 on: April 12, 2014, 06:43:14 AM
New results:
1: 080.8 vDC
2: 165 vDC
3: 0 vDC
4: 165 vDC
5: 078.5 vDC
6: 0 vDC
7: 100.8 vDC
8: 0 vDC
9: 100.4 vDC
10: 0 vDC
11: 0 vDC
12: 0 vDC
13: 165 vDC
14: 0 vDC
15: 185 vDC
20: 0 vDC
21: 206.5 vDC
A1: 078.4 vDC
A2: 0 vDC
A4: 0 vDC
A5: 0 vDC
A6: 080.4 vDC
A7: 0 vDC
A9: 0 vDC
B1: 079.9 vDC
B2: 164.8 vDC
B3: 100.6 vDC
B4: 078.5 vDC
B5: 165.1 vDC
B6: 101.4 vDC
B7: 0 vDC
B8: 0 vDC
Offline Rhok
Reply #38 on: April 12, 2014, 06:58:19 AM
Alright guys, it doesnt look like we're in the clear just yet - I tested the amp with a cheap pair of headphones I did receive audio (awesome! and thank you for getting me that far!) however, I'm not receiving any output from the right channel.
EDIT:
I've also took some additional pictures: http://s752.photobucket.com/user/mikemathis3/library/xx
« Last Edit: April 12, 2014, 07:29:09 AM by Rhok »
Offline Strikkflypilot
  • Shellac fiddler
Reply #39 on: April 12, 2014, 10:39:53 AM
Maybe a longshot but tried to swap inputs?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline Rhok
Reply #40 on: April 12, 2014, 10:52:45 AM
I did not, but I just tried - same issue.
  • Shellac fiddler
Reply #41 on: April 12, 2014, 11:10:19 AM
So You swapped inputs and still hear music on your left headphone speaker?
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline Rhok
Reply #42 on: April 12, 2014, 11:35:04 AM
I tried to plug the amp to my dedicated soundcard, a usb DAC, and onboard audio, tried swapping RCA jacks around, all resulted in left channel audio only.
If I connect the headphones directly to any of those devices stereo audio works in both channels.
Reply #43 on: April 13, 2014, 06:26:59 AM
Your voltages all suggest that the amplifier would pass signal.
You can temporarily short together the middle lug of each level of the volume pot, then see if the amplifier will play from both channels.
If it does, you probably have some solder shorting out the right RCA jack.
If it doesn't, you probably have a loose wire feeding the right channel of the headphone jack.
Offline Rhok
Reply #44 on: April 13, 2014, 08:10:49 AM
I believe this time around I checked the wires that should be relevant for the right channel very closely and do not see anything loose (or not making proper connection). I also don't see any solder that may bridge a connection to cause a short.
Could you please explain how to short the middle lugs of the volume pot for testing?
