Submissive / Quickie Integration
Guest · 16657
w0lfd0g
on: April 07, 2014, 05:30:17 PM
« Last Edit: April 25, 2014, 04:42:02 AM by w0lfd0g »
Reply #1 on: April 07, 2014, 06:28:33 PM
Not in a 6x10. It would, however be very easy to do a combination passive/active preamp using the two pieces in separate chassis utilizing a highly technical method called "moving cables."
« Last Edit: April 07, 2014, 06:31:12 PM by fullheadofnothing »
Reply #2 on: April 07, 2014, 06:47:49 PM
You could stack them on top of each other if space is at a  premium.
Reply #3 on: April 07, 2014, 06:52:32 PM
If you trimmed down the acrylic top plate, you could mount it below the Submissive in the same chassis (it should fit) on standoffs.
