Amp compatability
Dnorris · 3029
Offline Dnorris
on: April 10, 2014, 12:39:04 PM
I'm currently building an Eros, but plan on a BeePre next. The amp I have to drive is an SET (845/211 tube) with a 150 Kohm input impedance, 50 watt (Single ended, not balanced), 1.0 Volt for full output. I see that given the BeePre specs it puts out plenty of voltage, would that amp seem to be a reasonable fit with the BeePre or am I missing something obvious. Thanks.
Dale Norris
Reply #1 on: April 11, 2014, 06:00:08 AM
That amp will be a good match for the BeePre.
Offline Dnorris
Reply #2 on: April 11, 2014, 06:24:22 AM
Thank you, Paul. I thought so, but I wasn't sure about matching impedance, etc. Looking forward to adding some 300b flavor to my vinyl spinning. BeePre/BeeQuiet order on the way.
Dale Norris
