S.E.X. wiring for planars
Loquah · 6379
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
Reply #15 on: May 07, 2014, 07:34:31 PM
I think I'm swaying towards going and buying a 4-pin XLR socket so I can use my balanced cables with the S.E.X. as well as the Mainline. You might have just pushed me over the edge, Mark!
Reply #16 on: May 08, 2014, 03:45:50 AM
That evil voice in your head again, go on, you know you want to :P
You could do what i did and add both TRS and XLR sockets to the chassis, an easier option would be to make up an XLR to speaker binding posts cable using one of these http://www.neutrik.com/en/xlr/xx-series/nc4fxx-b
Personally i would just drill a hole in the chassis plate but i appreciate how awkward that would be on an assembled unit.
Offline Loquah
    • Passion For Sound
Reply #17 on: May 08, 2014, 11:15:35 AM
Yeah. I'm actually looking into something a little mental...
I'm going to use the reaming attachment for my Dremel to cut out the XLR hole in the place of the existing TRS and am then hoping to replace the binding posts with additional RCAs so that I can have signal into SEX, but then take signal out of SEX to run to the Quickie so I'm not always switching RCA cables. The trick now is to see if I can find an RCA socket that will fill and fit the hole made for the binding posts.
Offline Loquah
    • Passion For Sound
Reply #18 on: July 08, 2014, 07:20:34 PM
I finally managed to take the time to cut out the hole for an XLR socket in my S.E.X. and wired it balanced as per the great instructions here: http://bottlehead.com/smf/index.php/topic,3362.0.html
I'm currently listening to my LCD-2s with the new configuration and it's taken them to a whole new level of performance - more so than the T1s with the Mainline in balanced mode (i.e. larger leap, not necessarily better overall, just different)
(https://farm4.staticflickr.com/3837/14423626088_9997a47876_c.jpg)WP_20140709_15_13_48_Pro by Lachfen, on Flickr
