S.E.X kit bass thump
mcwhart · 2222
Offline mcwhart
on: April 11, 2014, 02:55:28 PM
Hello,
Listening to my iPod through a S.E.X. kit with upgrade, and I am noticing that bass-heavy tracks almost always produce a random thumping sound at some point during the song.  Using Blumenstein Orcas with Dungeness subwoofer.  The same effect can be heard through headphones.  Does anyone have any ideas around what might be causing this?
Thanks for your help
Reply #1 on: April 11, 2014, 02:59:24 PM
Sounds like your drivers are bottoming out. Might want to turn the volume down a bit.
Offline physicsmajor
Reply #2 on: April 12, 2014, 04:53:04 PM
Another possibility: I had something I would describe very similarly happen with a slowly-failing tube. I would get a sporadic VERY intense thump, but only in one channel. If you've got a sub, this might not be obviously channel specific.
In my case this was sporadic and didn't even require music playing or connected inputs.
Might also consider swapping the source and seeing if the effect persists.
