4P1L tubes for the Smash
airdronian · 11436
Offline airdronian
on: April 26, 2014, 11:00:49 AM
I'm not familiar with the 4P1L, and a quick search didn't seem to uncover many sources.
Were these strictly a Russian manufactured tube ?
Roughly how many hours of service could one expect out of these, implemented as they are in the Smash ?
Any info on these tubes would be appreciated.
Mark Bridges
Reply #1 on: April 26, 2014, 11:17:00 AM
I used them in an old tube amp to replace a pair of Chinese 4P1S tubes, i'm not aware of any other equivalents other than the Russian 4P1L.  Russian versions were the better of the two.
Online Paul Birkeland
Reply #2 on: April 26, 2014, 06:53:52 PM
There may be an old Telefunken tube that served as the basis for the 4P1L, but I'm not finding a reference to that in a quick search.
I don't know how many hours you could get out of one.  It might take several years of constant use to wear out a pair of tubes, and in that instance you wouldn't have the wear and tear from power cycling, so the number wouldn't be that helpful.
Offline Paully
Reply #3 on: April 27, 2014, 12:35:53 PM
Makes me wonder if there are other tubes that could be used with a simple pin-out change and maybe a resistor like the FPIII...  6SN7, etc...?
Reply #4 on: April 27, 2014, 01:16:41 PM
Sure, there are a crap ton of tubes that could be built into the chassis to function as a preamp.
The tough part is that few of them will be directly heated with adequate beef to function as a preamp tube without an output transformer, and of those that are that beefy, the filament requirements may be unreasonable.
