Mis-packed Speedball or alternate resistor option?
Stanshall · 2805
Offline Stanshall
N.B. This is for the Speedball kit.
Before I get in touch to request a replacement, I just want to check this isn't an equivalent.
Instead of the 150K 2W metal film resistor (brown, green, yellow, gold), I've received this resistor:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FR9N5Eqll.jpg&hash=8255ebac5722efe117aa29fbaf741400cb295de0)
Everything else is packed as expected so I'm able to do everything but solder these in place and install.
Anyone able to help?
« Last Edit: May 05, 2014, 03:46:50 AM by Stanshall »
Offline Stanshall
Reply #1 on: May 05, 2014, 04:29:06 AM
Alternatively, is there a way I can test with a multimeter to see if it's an eqiuvalent without finishing the job only to find that it isn't?
Reply #2 on: May 05, 2014, 04:44:56 AM
It's a mis pack. Email your contact information to replacementparts at bottlehead dot com.
The way to check with a multimeter would be to set your meter to resistance and measure with one probe on each lead, but that is definitely a 2.49KΩ resistor.
Offline Stanshall
Reply #3 on: May 05, 2014, 04:49:16 AM
Thanks for clarifying.
As I live in the UK, I think it'd be easier and quicker for me to just buy an equivalent 150K 2W resistor online. Presumably, that's no issue?
Apologies if this is a n00b question, I'm a n00b.
Reply #4 on: May 05, 2014, 05:16:05 AM
Well, definitely easier for me ;-)
The stock part is available from Farnell:
http://uk.farnell.com/vishay-bc-components/pr02000201503jr500/resistor-metal-film-150kohm-5-axial/dp/2396025
Offline Stanshall
Reply #5 on: May 05, 2014, 05:20:21 AM
Cheers. I'll get on it.
Not a wasted day, in any case, as getting my gear out means I've also finally put the Blue Alps in. Crack sounding great.
Offline jboehle
Reply #6 on: May 05, 2014, 02:55:00 PM
I had the same issue with my recent Speedball order:
http://bottlehead.com/smf/index.php/topic,6207.0.html
