ClarityCap TC 450VDC vs. 700VDC
thomas27 · 3947
Offline thomas27
on: May 13, 2014, 11:19:12 AM
Looking at previous posts it seems that many people are using ClarityCap TC 700VDC caps. Is there any issue with 450VDC versions or difference in sound maybe ? Other than being more expensive 700VDC caps are much bigger / difficult to fit under the chassis.
http://www.hificollective.co.uk/catalog/-c-61_68_408.html
I am looking at the potential cost of upgrading the output caps and last cap in the power supply.
Thomas
Offline galyons
  • Geary Lyons
Reply #1 on: May 13, 2014, 11:26:56 AM
Check the schematic and voltage test points.  The output cap is 160V.  The three PS caps are 250V. Higher voltage usually means heavier dielectric, but, IMO, generally not better sound.
Geary
Offline thomas27
Reply #2 on: May 13, 2014, 11:29:20 AM
Thanks Geary. Indeed, that's why I was surprised with people using the 700VDC caps.
It could just be because they are easier to source?
Offline JamieMcC
Reply #3 on: May 13, 2014, 11:37:36 AM
For some scale the Clarity cap 230 uf  is 62mm diameter x 100mm
My JFX 200uf is 57mm x 115mm
(https://www.head-fi.org/image/id/5980075/width/900/height/900/flags/LL)
The Clarity cap 110 uf is  52mm diameter x 76mm height
My JFX  100uf  49.5mm x 59mm  black cap at the bottom
(https://www.head-fi.org/image/id/5980078/width/900/height/900/flags/LL)
« Last Edit: May 13, 2014, 11:39:50 AM by JamieMcC »
Offline galyons
  • Geary Lyons
Reply #4 on: May 13, 2014, 01:01:23 PM
That would be my best guess!
Geary
