Foreplay III New Build + adjusting listening levels + ST-70 troubleshooting
syncro · 56527
Offline syncro
    • syncro architecture studio
The problem you describe on the Dynaco Tube Audio board sounds like a problem with the preamp.  That is easy to figure out just by swapping your input cables at the input of the ST-70.  If it moves then it is not in the ST-70.  But you have probably done that.
Well, I thought I had done this.  Today I bypassed the new how-could-the-problem-be-with-my-newly-built Foreplay III preamplifier.  Connecting the Hagerman Ripper directly to the ST-70 there is no imbalance in volume between channels.  I must have done something incorrectly in the changing of the input resistors operation.  Guessing I should test resistances across these input resistors and compare to opposite channel/specs.  Seems like a one-notch variation, but not exactly so.  Other ideas for troubleshooting this?  Guess I need to switch the 12AT7 tubes first and see if it follows the tubes.
In the mean time, the ST-70 has a new voltage divider configuration with the 470K + 360K + 180K (all three) parallel on the input side and the 47.5K to ground.  I measured 90.6K across the former (from memory) and the volume is about right.  I will wait to sort out the FPIII preamplifier issue before thinking about changing this in the ST-70.
David Bogle
LinnLP12>Hagerman Piccolo>Hagerman Ripper / Musical Fidelity V-90 DAC / Sansui TU-717>BottleheadFPIII>Yamaha M-45>Klipsch ForteII
   .   .   .     Today I bypassed the new how-could-the-problem-be-with-my-newly-built Foreplay III preamplifier.  .  .    I must have done something incorrectly in the changing of the input resistors operation.  Guessing I should test resistances across these input resistors and compare to opposite channel/specs.  Seems like a one-notch variation, but not exactly so.  Other ideas for troubleshooting this?  Guess I need to switch the 12AT7 tubes first and see if it follows the tubes.
I chuckle because this sounds like something I would have done.  The best laid plans...  and all.
Sounds like you have the input of the ST-70 sorted out at about a 2:1 ratio.
Offline syncro
Okay, I finally sorted out my mistaken placement of the input resistors in the Foreplay III.  Naively following only my intuition I had installed the resistors symmetrically, which looked good but padded the left channel of input 1 and the right of input 3.  Since I kept changing inputs and wires, thinking it was the ST-70, it was a moving target!
So, back to the ST-70, yes, I have about a 2:1 voltage divider padding the inputs now and I'm pretty happy with that.  I'm looking at modifying the inputs per the Van Alstine page mentioned above, so I'm not sure how this divider will work with that, but in the mean time I would appreciate a recommendation to optimize or simplify this voltage divider with just two resistors on each channel.
I am also curious, having bypassed the preamp in the troubleshooting, why my phono preamp (Hagerman Ripper) when connected directly to the amp is, or can be, very loud compared to the Foreplay.  It seems that the Ripper is designed to do double duty as phono + pre-amp.  It appears about the lower half of the volume steps are attenuating the inputs, and above that they're amplifying.  Is this happening with my CD input, and is this normal?
David Bogle
I looked at the AVA page.  The two filters on the input of the amp will attenuate the overall sound as well as the frequencies that they don't intend to become part of the feedback loop.  I don't know how much these filters will attenuate the midrange which is untouched by the filters.  Most likely more than you have right now.
According to the AVA site the assumption is that, "the driving source has a reasonably low output impedance."  Certainly the FP III is "reasonable" in that it includes a cathode follower stage so you can use longer than average cables.  Three feet is average.
With their suggested circuit you shouldn't need the 2.7:1 attenuator you have now.  A two resistor per channel attenuator for you now would be 33 k where the paralleled resistors are now and 10 k where the 47.5 k resistor is now.
As for the Ripper, it has full gain with no attenuated inputs, the FP III now has attenuated inputs.  Remember back to your post #16, you were rocking the house at three clicks.  With the stock 33 k ohm resistors it is considered unattenuated.  Now that you have attenuated the inputs and you use more of the volume control.
Offline syncro
Thanks again for the advice.  So, I don't need to approach the 470K ohm resistor-to-ground of the original spec input of the ST-70?   If that's the case, that lower resistances are suitable and the ratio is the design requirement, then I'll sort through my stock of resistors and come up with something - or just implement the AVA modifications and take it from there.
On the voltage divider I now have 96k and 47.5k to ground (= 2.0:1 ratio.)  Your suggestion of 33k and 10k to ground (=  3.3:1) would yield more volume, correct?
BTW, I'm happy with the sound of my system, thanks to the bottlehead designs/products and approach to sharing.
« Last Edit: May 28, 2010, 06:19:00 AM by syncro »
David Bogle
No, 470k is not necessary.  The spec for the FP III says a load of 10 k ohms or greater.
The 2:1 ratio (you are at 2.7:1 now).  The 3.3:1 would yield a higher volume.  But not by much, not discernible.  I was looking for a load under 100 k ohms.
