choosing a resistor
wwmhf · 18816
Offline wwmhf
on: April 17, 2010, 08:25:36 AM
Hi,
The previous owner of my Bottlehead amp did not use headphones and he took out the resistors across the headphone jack. Since I use headphone exclusively, I would like restore the original circuit by putting those resistors back. My trouble is that I do not have 120 ohm resistors. Instead I have the 100 ohm and 150 ohm. I have a few questions:
1. How critical are those 120 ohm resistors across the headphone jack?
2. What should I expect if I use the 100 ohm resistors?
3. What should I expect if I use the 150 ohm resistors?
Thanks in advance.
Reply #1 on: April 17, 2010, 09:13:05 AM
Which headphones do you plan to use mainly?
Offline wwmhf
Reply #2 on: April 17, 2010, 09:35:40 AM
I will mainly use a Sennheiser HD650
Reply #3 on: April 17, 2010, 10:58:22 AM
How do they sound to you now?  Do you have enough range on the volume control, or is it really touchy?
Offline wwmhf
Reply #4 on: April 17, 2010, 11:11:30 AM
I noticed that the resisters were missing because my headphones sounded too loud. I have to turn the volume knob to a very low position to listen.
I have tried three resister values:
100 ohms: works, sounds OK
150 ohms: works, sounds OK
180 ohms: works, the amp looses some details.
I think I can live either with 100 ohm or 150 ohm resister, but I really like to know a little more about the characteristics of these resisters.
Reply #5 on: April 17, 2010, 11:52:15 AM
I'm working on a short white paper about this subject. Ping me with your email address and I'll send a draft copy - I haven't found a way to send attachments through the PM facility.
Offline wwmhf
Reply #6 on: April 17, 2010, 01:09:48 PM
PM was sent.
Reply #7 on: April 17, 2010, 02:33:22 PM
Sorry, meant to reply but I was running a beta of my screen reader and it wasn't cooperating with my web browser.  Looks like you'll have a very complete and educating answer coming your way :D.
