Help Troubleshooting a Speedball
thdewitt · 3167
Offline thdewitt
on: May 20, 2014, 12:22:09 PM
Hello,
I have enjoyed my crack for a few months and decided to install the speedball.  After assembly on first power up, i got smoke from r2 resistors on both boards and from the mje350's.  I have ordered new parts from Mouser (4 of each just in case).  I have taken the 3 boards off and checked all my wiring and components and I can't seem to find the problem.  I do have a few questions.
1) One of my small boards has 3 holes next to the G.  The r2 goes in the center.  Can I put the other wire in either hole since one has been cut off the board.
2)The B+ holes on the big board are very close together and at this point are shorted together from taking the boards in and out.  Is that a problem.
3) The two holes next two each other on both the O and G points on the big board are close and shorted as well.  Is that a problem.
4)  What parts do you recommend I replace before reinstalling so I don't just blow up the next batch of parts.  Any ideas on ways to test.  I do have a oscilloscope, function generator, DMM, and variable power supply if any of this equipment will help to test.
Tom
Eros Telefunken EF806S and Telefunken E88CC
BeePre JJ 300B
Paramount 1.1 EH 300B
Stereomour JJ 2a3-40 and Mullard CV4024
Crack Tung Sol 5998  Mullard CV 4003
Thorens TD 160 Super (Vinyl Nirvana)
Blumenstein Orca Deluxe/Dungenus Sub
Blumenstein Mako Floorstanders Chocolate Bamboo
Offline Strikkflypilot
  • Shellac fiddler
Reply #1 on: May 21, 2014, 06:05:29 AM
1. The three paralell holes to the right of R2 are all shorted and equal.
2. The B+ holes on the large board are shorted.
3. Those are shorted.
I made these same observations and wondered if they could be problems. These are design choices.
It has not lead to problems soldering. You might notice that solder flows to adjacent shorted connection points. Not a problem as long as they are not covered as You could have problems installing leads. A solder wick would solve that too.
I also fried components due to bad soldering. I thought my soldering looked good and did not check that they actually conducted with my DMM. Bad move.
I would measure resistances if You didnt already as some kits have been shipped with wrong resistors causing them to fry.
Then, of course, I also had TONs of help from Caucasian Backplate
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #2 on: May 21, 2014, 06:44:18 AM
Did you measure the R2's to be 150K?
Offline thdewitt
Reply #3 on: May 21, 2014, 06:48:21 AM
I thought I measured them but cant be sure now.  I know I measured most resistors because they were too small to read.  When I removed them they were completely wrong at that point 3K or something like that.
Tom
BeePre JJ 300B
Offline thdewitt
Reply #4 on: May 21, 2014, 07:54:28 AM
Am I right in assuming that you use the original Crack Manual to test the resistance?  I would need to reinstall the 3 boards and then use the same points as the original crack to test the resistance?
Tom
BeePre JJ 300B
  • Shellac fiddler
Reply #5 on: May 21, 2014, 10:16:05 AM
Actually, I meant more like what CB asked. If You really are certain that the proper resistors were in place before it went haywire. When I did my troubleshooting, I checked and doublechecked all resistors.
Luckily You can do as I did and revert to stock crack for the time being. It is more than enjoyable.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline thdewitt
Reply #6 on: May 27, 2014, 06:01:25 PM
Just in case anyone is interested.  The R2 resistors that came with my crack kit were the wrong resistors, that is why they burnt out.  Once I got the new ones from Mouser and put them in, everything is working fine.  Thanks for everyones help.
Tom
BeePre JJ 300B
