Bottlehead Kits
Crack
Gauge wires
Gauge wires
lordnikon
2522
lordnikon
Jr. Member
Gauge wires
May 23, 2014, 10:05:45 PM
edit
Last Edit: May 28, 2014, 03:54:59 PM by lordnikon
Grainger49
Hero Member
Re: Speedball Resistor
Reply #1 on:
May 24, 2014, 12:55:38 AM
You are fine. Resistors are non-directional,
most
other components are directional. So it looks like you are good to go.
DO measure the resistance to be certain you have a value of about 44.2k Ohms.
Last Edit: May 26, 2014, 02:26:49 AM by Grainger49
lordnikon
Jr. Member
Reply #2 on:
May 24, 2014, 09:38:26 PM
Update:
I'm about to solder the wires onto the PCB boards and I realised I made a stupid mistake. I used the old 20 gauge wires for the Speedball upgrade instead of the thinner wires. In this case, would the Crack still work or will the resistance change because of the thicker wires.
Oh man.....things aren't going well for me today
JamieMcC
Hero Member
Re: Gauge wires
Reply #3 on:
May 24, 2014, 10:14:20 PM
Don't worry your not alone I did the same thing PB confirmed it was not an issue and my Speedball has been working fine with the 20awg for the last six months.
Loon
Guest
Re: Gauge wires
Reply #4 on:
May 25, 2014, 04:22:33 PM
No worries. It will be fine and is quite normal. Just make sure they are oriented in the same direction as the pictures in the manual.
lordnikon
Jr. Member
Re: Gauge wires
Reply #5 on:
May 26, 2014, 03:14:28 AM
Speedball installed and working. Woohoo Thanks everyone
Bottlehead Kits
Crack
Gauge wires
