Bottlehead Kits
Legacy Kit Products
Quickie
New Quickie... but need help
tominredbank
3051
tominredbank
Jr. Member
May 27, 2014, 12:29:59 PM
Hi, jsut finished the Quickie and I need a litte advise. All voltages and resistances are to spec. But is it normal to have full voltage at 1-6-2-7- with rotary in off position?? When playing a cd and switched off the music stops( but voltage to those terminal remains 29v - 38v. I checked and double checked my work. Thanks.....tom
Grainger49
Hero Member
Re: New Quickie... but need help
Reply #1 on:
May 27, 2014, 12:38:43 PM
Here is a thread you should read all the way through:
http://bottlehead.com/smf/index.php/topic,1667.0.html
Post
only
resistances and voltages that are out of spec by more than +/-15%. Post what you have and what it should be.
mcandmar
Hero Member
Not all engineers are civil
Reply #2 on:
May 27, 2014, 02:07:12 PM
That is perfectly normal as the switch only turns the filament heaters on/off.
tominredbank
Jr. Member
Reply #3 on:
May 27, 2014, 02:12:40 PM
Thanks for the reply. I checked everything 3 times. Doesn`t that run down the batteries?
mcandmar
Hero Member
Reply #4 on:
May 27, 2014, 02:19:16 PM
Apparently not as without the filament heaters no current flows through the tube, so its an open circuit in effect.
tominredbank
Jr. Member
Reply #5 on:
May 27, 2014, 02:29:04 PM
Thank you very much. It was driving me nuts! Tom
Global Moderator
Hero Member
Reply #6 on:
May 27, 2014, 03:54:15 PM
This one is not obvious, and not exactly intuitive. But it's an old trick used in battery radios since the early thirties, possibly earlier. You get to use a cheaper power switch, still important for a $99 preamp!
Bottlehead Kits
Legacy Kit Products
Quickie
