Gold Point Mini-V Custom
thdewitt · 2199
Offline thdewitt
on: May 27, 2014, 06:06:42 PM
Hello,  I have been trying to look through the forum for this information but I can't seem to find it.  I would like to build a Gold Point Mini-V custom for my Crack.  I need to know what the basic Attenuator should be to put in a Crack (how many ohms).  I think i read somewhere it should be 100K ohm.  Is that right.
So I buy a mini-V and then build in the 23/channel of the Dale Vishay resistors at the amounts listed on the site. So a total of 46 resistors to equal a 100K ohm stepped attenuator.
Does that sound right?  Is there any reason to buy the one already built with the surface mount resistors and just be done with it.  Or is building it with high quality resistors a better way to go.  Sounds like more fun to build it myself, but the price for the one already built is actually cheaper.
  Thanks, Tom
« Last Edit: May 27, 2014, 06:14:09 PM by thdewitt »
Eros Telefunken EF806S and Telefunken E88CC
BeePre JJ 300B
Paramount 1.1 EH 300B
Stereomour JJ 2a3-40 and Mullard CV4024
Crack Tung Sol 5998  Mullard CV 4003
Thorens TD 160 Super (Vinyl Nirvana)
Blumenstein Orca Deluxe/Dungenus Sub
Blumenstein Mako Floorstanders Chocolate Bamboo
Reply #1 on: May 27, 2014, 07:43:32 PM
100K is the recommended value for the control.
Personally, I would take the Vishays over the SMT parts, but YMMV.
Reply #2 on: May 28, 2014, 03:01:14 AM
You can use 50k-200k Ohms.  The stock 100k is in the sweet spot of that range.
Be certain to get an Audio Taper, Stereo pot.
