quickie interference - SOLVED
aragorn723 · 3808
Offline aragorn723
on: June 09, 2014, 03:17:10 PM
Hi,
Is there a way to reduce transformer noise from my amp from conducting to the Quickie?  The Quickie is in an entertainment center on a shelf, and the amp is below that.  The whole thing needs to be protected from my little boy, so there's a plastic gate in front of the whole thing.  Would covering the wooden box with a metal plate on the bottom help?  Any other ideas to reduce the hum?  Thanks,
Dave
« Last Edit: August 31, 2014, 05:19:40 PM by Doc B. »
Reply #1 on: June 09, 2014, 04:56:13 PM
Assuming it's magnetic field coupling, a mild steel plate under the Q would likely help. 1/4 inch is not too thick. It is probably the easiest, cheapest way to determine if that is in fact the problem. If it helps, but not enough, then google "magnetic shielding" for more than you ever wanted to know...
Offline aragorn723
Reply #2 on: June 11, 2014, 02:55:33 PM
what's a good place to find a metal plate like this?
Dave
Reply #3 on: June 11, 2014, 05:38:50 PM
How about a cast iron frying pan to test...John
Reply #4 on: June 11, 2014, 05:43:19 PM
Onlinemetals has 1008 steel (low carbon = good magnetic proerties, as I understand it) up to 0.075 inch thick, i.e. 14 gauge. The frying par test is a great idea, though it may not have the best properties it IS think!
Offline aragorn723
Reply #5 on: July 02, 2014, 02:38:21 PM
Offline aragorn723
Reply #6 on: August 31, 2014, 04:09:21 PM
not sure if anyone has read this thread in a while, but the hum turned out to be from my dac, not the quickie  ;D  After changing the dac from AC power to usb (battery) there is almost no hum.  Thanks,
Dave
