NAWA Assembly
bobster · 4590
Offline bobster
on: June 10, 2014, 02:19:08 AM
I came across an old NAWA kit that I want to put together but can't find the instructions.
Will the Bottlenect instructions work for this kit?
Thank you
Bob
Bob Musson
Seduction (extended), Foreplay, Paramours, Klipsch Heresys, Orcas, Crack plus HD 600s
Lovin the Bottlehead sound in Maryland
Reply #1 on: June 10, 2014, 04:43:54 AM
They sort of will.
Essentially, the Nawa wire has two hot conductors, two cold conductors, and a shield.  Everything wires up as you would expect, except that the shield only connect on one end.  On the end that the shield connects to, use the "source" heatshrink to mark it.
