more db ???
Guy Boisvert · 1656
Offline Guy Boisvert
on: June 15, 2014, 05:09:48 AM
If I'm feeding an amp [for example a Stereomour]  from a Mac computer , could I get more "punch" by using a pre-amp between the Mac and the amp ??
Reply #1 on: June 15, 2014, 07:33:37 AM
Hello Guy,
This very much depends on how much voltage your source can deliver.  You can run a 60 Hz tone through your computer, then measure the AC voltage at the output jack.  If you don't see several volts here, a preamp may make some sense.
Reply #2 on: June 15, 2014, 02:25:54 PM
will try that; thanks Paul
