60hz hum develops after 6-8 hrs, and HOT
aroide · 6950
Offline aroide
Reply #15 on: June 30, 2014, 01:31:50 PM
Thanks for the advice.  I did find some tubes when searching  for p vs pi.  I ordered 2.
While I had the preamp out for replacing my loose 300b socket, I put everything back and checked voltages.  Sure enough, terminal 6 is 185V (with the dead EL84 on that side) while terminal 11 is 146V.  If I swap EL84s, the voltage imbalance follows.  I must have been operating this way for a 8-15 hours or so (I know last week both EL84s were glowing).  And the preamp sounds great.
Have I been hurting anything operating this way?  I'm sure I've stressed the circuits around.  But they work with a working tube so all is well as far as I can see.
Mac mini running Roon->
Mytek Brooklyn DAC+->
Darwin Truth RCA IC->
BeePre (BeeQuiet,  Mundorf Ag/Au/Oil, Sophia Royal Princess 300B)->
Audioquest Colorado->
Rogue Audio Atlas Magnum amp (Psvane small signal tubes, KT150s)->
Audioquest Gibraltar-speaker cables>
Magnepan 1.7 & REL T-5
Reply #16 on: June 30, 2014, 01:35:35 PM
If it's working, it's working. If parts were stressed to the point of failure they would have failed. Now you can sit back and enjoy.
Offline aroide
Reply #17 on: June 30, 2014, 04:47:27 PM
Thanks Doc!  As soon as the new EL84s arrive, I'll pop one in and let the toe tapping begin again.
