paint for the transformer bell
mozarti · 2728
Offline mozarti
on: July 03, 2014, 11:56:27 AM
Does anyone know how hot the transformers of Beepre are likely to get?  I am thinking of using the regular Rustoleum paint to color the bells, and I have no idea whether it will be able to resist the hot temperature of the transformers.
By the way, the paint can says that it is not necessary to use a primer.  So my plan is just to sand the bells with 600 grit paper and use couple of coats of paint.  Does this make sense? Thanks.
Reply #1 on: July 03, 2014, 12:20:15 PM
I haven't run into a paint yet that is that vulnerable to heat.  I would caution against something like paint you would use on the exterior or interior of your house, but otherwise you should be safe.
Sanding the covers is good, as is a thorough degreasing.  I have dedicated sponge at home for this task, and I degrease before sanding.
Offline mozarti
Reply #2 on: July 04, 2014, 02:58:56 AM
Thank you, Paul. This is reassuring.
