Dressing up an M6 termination
EarWorm · 1933
Offline EarWorm
on: July 18, 2014, 01:04:04 PM
I'm looking for advice on terminating the Clarity Cap TC M6.   I want to place them up top on a new chassis and I'd like to terminate the studs so they are safe and covered and look nice at the same time.
« Last Edit: July 18, 2014, 04:46:30 PM by EarWorm »
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Reply #1 on: July 18, 2014, 01:08:25 PM
Drill two round holes in the chassis that will fit those cast protrusions that hold the M6 threads.  Buy M6 fiber fender washers, remove both nuts from both studs, then use the non-conductive washer to clamp the cap to your chassis plate.
It would be worth measuring those protrusions individually, as the manufacturer may allow for some variation in their exact position.
Your other option is to get a clamp and cut a large diameter hole in the chassis for the body of the cap to slide through.
