Help for building CRACK with Speedball
i luvmusic 2 · 13692
Reply #45 on: August 31, 2014, 03:59:03 PM
What is the problem with listening at 5 or 6 clicks?
Offline i luvmusic 2
Reply #46 on: August 31, 2014, 04:07:04 PM
On 5th clicks sound low if i go 6 clicks it sound loud to my liking.Any position below 5th it sound too low for me and past 6th is too loud.
« Last Edit: August 31, 2014, 04:10:02 PM by i luvmusic 2 »
Reply #47 on: August 31, 2014, 04:14:35 PM
If i will reinstall the stock pot or the ALPS pot what can i do to solved the channel imbalanced?Thanks!
Reply #48 on: September 01, 2014, 06:53:48 AM
Offline Atraf
Reply #49 on: September 01, 2014, 04:03:19 PM
I was planning on installing the the Alps Blue Velvet pot as a solution for the imbalanced in low volumes..
Are you saying only a stepped attenuator can fix that? (Besides the FAQ solution...)
Reply #50 on: September 02, 2014, 10:48:23 AM
Thank You PB!
Reply #51 on: September 02, 2014, 10:53:36 AM
 Alps Blue velvet did not fixed The  channel imbalanced the Attenuator does but my comfortable listening level is not matching the 23 stepped attenuator's settings.
 I found a 48 stepped attenuator but it's not cheap $179 @ PartscoX104.I will do The resistor mod instead.
« Last Edit: September 02, 2014, 10:57:29 AM by i luvmusic 2 »
Reply #52 on: September 02, 2014, 11:53:58 AM
I still think you could just listen at step 6 and call it a day.
Reply #53 on: September 02, 2014, 12:28:43 PM
I could but honestly i prefer the sound of the STOCK POT or the ALPS BLUE.
Offline Atraf
Reply #54 on: September 02, 2014, 02:53:32 PM
Would it be that bad playing with the volume of your music source?
Put it on 6 and decrease the volume from a 100% to 95% or something on your music source.
About the attenuators, I was really sure that everybody replace the stock pot because of the imbalanced issue now I see its only for sonic benefits..
Reply #55 on: May 23, 2015, 11:25:15 AM
 My crack is humming if no input signal or if i unplug the RCA Cables the hum starts once the pot is at 10 o'clock and it gets louder as it reach the max volume.If the signal is present the CRACK is dead silent even the pot is on max no hum.
« Last Edit: May 23, 2015, 11:30:26 AM by i luvmusic 2 »
Reply #56 on: May 24, 2015, 03:54:29 AM
The proper way to check hum is to short the inputs at the RCA jacks.  You can either use jumpers or shorting plugs.  The open RCA jacks can pick up noise.  Give that a try and report back.
Reply #57 on: May 24, 2015, 05:30:35 AM
Hi Grainger49,
 I used a test clips and shorted the input RCA jacks like you described and if they're shorted(Centre pin to outer sleeve)no noise/dead quiet and if i removed the test clips on the outer sleeve of the rca jack leaved the test clips clipped onto the centre pin of the rca jack i can hear the music playing even though these rca jacks are not plug in to my source and if i touch the test clips that is clipped onto the centre pin the noise it gets really loud.So i guess i'am picking up interference.
THANK YOU!
I just unplug the jumpers from the rca centre pin and the music disappeared but the noise gets louder.
Thanks again!
« Last Edit: May 24, 2015, 05:36:26 AM by i luvmusic 2 »
Reply #58 on: May 24, 2015, 07:15:54 AM
I think the noise is caused by something outside of the Crack.  Are there any other electrical devices near it?
Offline ALL212
Reply #59 on: May 24, 2015, 07:18:44 AM
Could one of your tubes be going bad?
Aaron Luebke
