Re: Crack Manual - terminal designations
Jim R. · 16651
on: April 26, 2010, 09:01:14 AM
Doc,
In the section pasted below, wouldn't it be more consistent and a little les potentially confusing to call the "center terminal" T3 instead?:
Nine pin socket A wiring
You will now install the two LEDs that set the bias voltage of the input tube. These
LEDs have a
silver band at one end of the red body. It is absolutely critical that they are installed
with this silver
band connected to the proper terminal.
( ) Attach the silver band end lead of one LED to the center terminal of the nine
pin socket A. Don
Reply #1 on: April 26, 2010, 09:40:24 AM
"Center terminal" means the center terminal right in the middle of the nine pin socket, not T3.
Reply #2 on: April 26, 2010, 10:09:39 AM
Ok, just looked at the socket -- never saw a 9-pin socket like that.  What is this connected to as I don't see any other connections listed in the manual for this point?
Just trying to understand what is probably very obvious to everybody else.
Reply #3 on: April 26, 2010, 10:16:52 AM
The center pin of the socket isn't connected to anything internal to the tube, but in the manual you will eventually run a wire from that terminal to terminal 3 (ground).
Reply #4 on: April 26, 2010, 10:28:22 AM
Ok, but that sort of brings us back to where I started :D.
I just didn't see the words "center terminal anywhere else in the manual except with regard to the RCAs and in the checkout section.
Thanks for the clarification,
Jim
Reply #5 on: April 26, 2010, 01:57:40 PM
That may be something that is only clear if you can see the picture.
Reply #6 on: April 26, 2010, 07:16:46 PM
Grainger,
I was doing my usual exercise of converting the pdf to a text file so I could prune it down to the necessary steps, eliminate all the blank space taken by photos and drawings, incorporate notes to myself, and fix the errata, when I came on the step about adding the wire from the center terminal of the tube socket to terminal strip lug 3, so I found it and now everything is crystal clear.
Hopefully I can make some good progress on this tomorrow.
Reply #7 on: April 30, 2010, 09:30:03 AM
Ok, think I've got it all sorted out, the corrections made, etc.
Now, can one of the BH folks tell me what gauge the supplied wire is?
Jim
Reply #8 on: April 30, 2010, 10:24:02 AM
22 gauge, solid core.
Reply #9 on: April 30, 2010, 01:42:29 PM
Thank you, doc.
