Bottlehead Kits
Legacy Kit Products
Quickie
New Quickie Voltages are High (Solved)
Sugar Man
2947
Sugar Man
Full Member
July 29, 2014, 03:48:32 PM
Just built my Quickie and my voltages are all high.
1 - 42.7
2 - 57.4
3
4 - 3.8
5 - 0
6 - 45
7 - 57.4
8
9 - 3.2
10 - 0
Everything on the build seems right. My resistance checks were a little weird until I put the tubes in, then they were spot on.
Any help would be greatly appreciated. Thanks!
Last Edit: July 29, 2014, 04:22:42 PM by Sugar Man
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
mcandmar
Hero Member
Not all engineers are civil
Re: New Quickie Voltages are High
Reply #1 on:
July 29, 2014, 04:01:11 PM
I have no idea how you are seeing 57v, thats just weird. Try measuring a few batterys on their own and see if you get sensible readings, just to verify your meter is ok.
Sugar Man
Full Member
Re: New Quickie Voltages are High (Solved)
Reply #2 on:
July 29, 2014, 04:22:13 PM
Thanks for the reply. My lovely fiancé had the same idea to check my meter. Grabbed a new 9V battery out of the Quickie and it measured 14.25 Volts! That is about the same ratio that my measurements are off, so it looks like the meter is measuring high.
Mike "Stein" Ayotte
Current Gear:
Bluesound Node 2i
Grainger49
Hero Member
Reply #3 on:
July 30, 2014, 01:17:50 AM
That goes back to the ongoing discussion of cheap meters causing more problems that Bottleheads imagine. There are good meters out there for $40.
Sugar Man
Full Member
Reply #4 on:
July 30, 2014, 06:19:17 AM
Very true about "cheap" things in general. I actually have a great meter, but can't find it in the garage, so had to use my old cheap backup. I also brought out my old Weller soldering station and it performed perfectly.
Mike "Stein" Ayotte
Current Gear:
Bluesound Node 2i
Bottlehead Kits
Legacy Kit Products
Quickie
