hum balance potentiometer
kompakt · 3786
Offline kompakt
on: August 07, 2014, 11:27:51 PM
Hello!
 I bought a stereomour in 45 config, and i like to build the the stereomour now for 2a3. the previous owner hast remove the hum balance poti.. In pdf manual is this a 10ohm potentiometer. Now i wanna buy witch and dont now if  a 10ohm ( 1W ) is ok  for this job. How much watt most have this potentiometer?
Best Regards
Seyed
Reply #1 on: August 08, 2014, 03:08:43 AM
The power rating should be on the parts list at the beginning of the manual.
By the way, the hum balance pot should still be needed for 45 operation.  I have no idea why it was removed.
Reply #2 on: August 08, 2014, 03:42:58 AM
The actual power is very low,  but I specified a wirewound pot because they are reliable and quiet.
Offline kompakt
Reply #3 on: August 08, 2014, 05:47:12 AM
Hello!
On the pdf manual is only 2-10 ohm wirewound potentiometers.. and n how much Watt..
I have found this 10ohm wirewound  Pots on ebay:
http://www.ebay.de/itm/2-Stuck-DDR-Potentiometer-Poti-Drehwiderstand-10-Ohm-10R-1Watt-Einstellregler-/281078995470?pt=Bauteile&hash=item41719d1a0e
Do you think this are ok?
Regards
Seyed
Reply #4 on: August 08, 2014, 07:43:10 AM
Offline kompakt
Reply #5 on: August 08, 2014, 09:15:25 AM
Thank you very much.
regards
Seyed
