40+ Stepped Attenuators
EarWorm · 6931
Offline EarWorm
Reply #15 on: August 11, 2014, 09:57:08 AM
I remember text books.
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Reply #16 on: August 11, 2014, 10:20:09 AM
I've got one of the best under my forearm as I type.  It is Circuit Analysis, but doesn't cover dB.
Online Paul Birkeland
Reply #17 on: August 11, 2014, 10:24:35 AM
Reply #18 on: August 11, 2014, 10:38:02 AM
Paul, thanks, that is what I thought.  It is now bookmarked.
Reply #19 on: August 11, 2014, 05:29:42 PM
History explains some of that:
A "Bel" (named fro Alexander Graham Bell of course) is a factor of 10 in power - 10 watts is one Bel greater than 1 watt. So Bel = log10(power ratio).
A deciBel is a tenth of a Bel, so dB = 10*log10(power ratio).
Power is proportional to voltage squared if the resistance does not change, so dB = 10*log10(voltage ratio squared) = 20*log10(voltage ratio). That's why logs are so useful, exponential powers turn into multiplication in the log-world.
Power is also proportional to current squared if the resistance does not change, which you can remember with "twinkle twinkle little star / power equals I-squared R".
DO NOT use the second verse "little star up in the sky / power equals R-squared I" - you will flunk the test as many before you have done!
More historical nonsense - current is I for Intensity, voltage used to be EMF for Electromotive Force, E for short. Mostly people use V for Voltage and let the history go, but so far I remains with us. ... yes, we no longer let the Force be with us, just the Intensity. Kind of sad.
Offline EarWorm
Reply #20 on: September 03, 2014, 03:38:30 PM
Are there any folks who have forgone an attenuator all together and made the Crack a stand alone amp onto itself to be driven by a pre amp or variable source?
Reply #21 on: September 03, 2014, 03:45:27 PM
Yes, this is one of the roles we intended for the Submissive.
