40+ Stepped Attenuators
EarWorm · 6919
Offline EarWorm
on: August 10, 2014, 09:26:17 AM
Anyone have working knowledge of 40+ stepped attenuators in their Cracks?
  I'm afraid the 20 or so steps just won't be enough control.  I know the 40+ are expensive but...
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Reply #1 on: August 10, 2014, 09:42:53 AM
You could add a DPDT switch make a 20 step switch into a 40 step switch.
Offline JamieMcC
Reply #2 on: August 10, 2014, 11:46:17 AM
The 36 step set up with the course and fine adjustment like the Submissive is a joy to use.
If you have not seen it http://bottlehead.com/submissive-volume-source-control-kit-specs/
Offline i luvmusic 2
Reply #3 on: August 10, 2014, 02:13:49 PM
  Hi all instead of creating another  thread i decided to post my question here.Anyone is familiar or have used KHOZMO 48 STEP ATTENUATOR?This one is from Partsconnexion for $179 i think it's not bad.Thanks!
Offline EarWorm
Reply #4 on: August 10, 2014, 04:51:02 PM
That Khozmo attenuator looks even sweeter when Parts Conexxion runs it 20% off sale.
 I fell under the 20% spell last month and now I own capacitors the size of trash cans. ;D
The 41 stepped attenuator from Acoustic Dimensions seems to be popular among folks who are left wanting from 20 stepped attenuators.  Not sure how many folks put the 40+ in a crack because of their price. I am very sensitive to volume changes and channel balance so the 40's seem the place to start for me.  I always seem to want a volume on the 20's that falls in between settings.  I blame my editing battered ears which have endured 24 years of high end editing in NYC.  That's a lot of volume adjusting through the years and ones ear gets sensitive to that kind of thing.
I'm not opposed to a smooth well made continuous control though.
Offline JamieMcC
Reply #5 on: August 10, 2014, 09:45:06 PM
There is a pic of a Crack with a Khozomo fitted somewhere it is a big unit seem to recall the small speedball where moved or left flying on their leads to make enough room for it.
Reply #6 on: August 11, 2014, 01:26:06 AM
 Yeah i installed this PoS and i'am not liking at all it sounds like congested and reduced in bass and details.According to the vendor this PoS is stereo but it could be Mono.
https://www.head-fi.org/content/type/61/id/1168192/width/500/height/1000/flags/LL
(http://)https://www.head-fi.org/content/type/61/id/1168191/width/500/height/1000/flags/LL
Reply #7 on: August 11, 2014, 01:42:24 AM
Before buying a Foreplay 2 I had an Audio Research Corp.  SP-14.  It had 3 ranges for volume and many steps on the volume control.  I could usually reach the same physical volume level on all three ranges.  So it was redundant.  But the suggestion of a selector switch with a dropping resistor for a low range, the first response to your post, would give you a lot of versatility.
« Last Edit: August 11, 2014, 03:30:48 AM by Grainger49 »
Reply #8 on: August 11, 2014, 01:48:46 AM
 Now i'am done with this attenuator shopping no more expensive Attenuators but since my stock POT developed some kind of a sticky spot if i turn the shaft.I will get one of those ALPS pot and Mundorf caps.
Offline EarWorm
Reply #9 on: August 11, 2014, 07:15:56 AM
How might one go about adding a selector switch with a dropping resistor for a lower range?
Reply #10 on: August 11, 2014, 07:36:11 AM
What is the impedance/resistance of your attenuator?
Offline EarWorm
Reply #11 on: August 11, 2014, 08:08:02 AM
Grainger I don't have one yet.  I'm looking for advice on possibly getting a 40+.  Size won't matter because I intend on making a larger chassis.
As a side note to the Audio Research gear, I once owned an SP 8 and an SP 10.   Loved the sound of both units.  I eventually sold both units because I really want to see the tubes in a piece of gear on the outside.  Had some Conrad Johnson stuff also. Same thing.  Tubes hidden inside.   Free those valves!  Tubes should be seen and heard.
ILuvmusic 2' perhaps you have seen the video from HiFi Collective on tweeting the Khozmo.
Reply #12 on: August 11, 2014, 08:43:12 AM
Ok, I'm screwy about dB and attenuation.  So here goes....
If you have a 100k Ohm attenuator (a standard value) you can put a 100k Ohm resistor and cut the voltage in half.  According to the internet that is 1/2 the voltage.  For more attenuation you can use a 220k Ohm resistor.  All these are standard values.
You would bring the inputs that would go to the volume control to the DPDT toggle switch.  You solder them on the center lugs.  A DPDT toggle switch has 6 lugs on it.  So the center ones are fairly obvious.
From one of the end lugs you would take the resistor to the "input" of the stepped attenuator.  From the other two lugs you take wire to the same two input lugs of the stepped attenuator.
Be careful not to cross up right and left.
Imagine the 6 lugs being split into right and left three lugs, down the center.  Here is what isn't intuitively obvious:  when the switch is "down" it attaches the top and center lugs for left and right.  When the switch is up it connects the bottom and center lugs for right and left.
Is this helping?
Offline EarWorm
Reply #13 on: August 11, 2014, 09:26:17 AM
Thanks Grainger that does help quite a bit.  Not sure if I'll go that route just yet but now my brain is sifting it around.
When you say you are screwy about dB and attenuation do you mean theoretically or being very sensitive to level changes?
Since we are on the subject of volume controls and I have limited knowledge,  it is not totally clear why folks are so fond of stepped devices.  Are they  a preference for quality volume control because of a design inherently superior to other types?
My sonic gut tells me that even 40 steps might prove a bit annoying in time so I'm also open to a high quality continuous volume control of which I know nothing about.
Reply #14 on: August 11, 2014, 09:47:11 AM
It is not hard to add it afterward.
I couldn't find a true formula for dB attenuation relative to voltage.  I know it is a Log10 function but will have to drag out a text book to follow it.
