Quickie 1.1 Selector Switch Assembly Question
SailorMac · 2742
Offline SailorMac
on: August 16, 2014, 04:14:18 AM
Underneath the lock watcher there is a retaining washer which fits into a slot on the top of the switch, the slots are to the right of numbers 2-11. Which slot should it be in? I flipped it over when taking the lock washer off before I noted the position.
Cheers!
Jeffrey Jurik
Klipsch Kg3's - Hafler DH500 - Bottlehead Quickie - CNC Phono Stage (P2P) - Pro-Ject Debut Carbon TT
Reply #1 on: August 16, 2014, 04:34:55 AM
The indent sets the number of positions the switch has so find the position that gives you three clicks, i.e. off-input1-input2.
Offline SailorMac
Reply #2 on: August 16, 2014, 04:51:48 AM
Thanks. That's the hole slot to the right of 3 (which makes sense).
Cheers!
Jeffrey Jurik
