I have a couple Quicksand questions
Pfenning · 7393
Offline Pfenning
  • My knockoffs
    • This is the place
on: August 17, 2014, 01:04:43 PM
What are the recommendations for speakers? I assume high efficiency is the key. Can I run some high efficiency Pro audio monitors full range to room filling volumes? Can I power it with my Dewalt 18 volt rechargeable batteries? It would be cool to run a small PA rig in my garage off my tool batteries.
Pfenning
Pfenning
Reply #1 on: August 17, 2014, 02:48:15 PM
The answer is probably yes.  If your room is an airplane hangar, then no, but if your room is reasonable, then you should be just fine.
That's kind of been a running joke in the office, that we should build an amp that will take a power tool battery.  If you can figure out how to make good connections, that will work just fine.
