Discharging nicad batteries
Cary · 2512
Offline Cary
on: August 20, 2014, 04:39:14 AM
What is a good way of discharging nicad batteries other than leaving them on? Can I use a bleeder resistor like in discharging a cap? If so what should be the value of the resistor?
Reply #1 on: August 20, 2014, 04:53:18 AM
Got to ask, why do you want to?
Personally i would just connect them to a load like a small light bulb.
Reply #2 on: August 20, 2014, 06:42:14 AM
I use a resistor under 20 Ohms.
They charge better when fully drained.
Offline Natural Sound
Reply #3 on: August 20, 2014, 10:46:40 AM
There are "smart chargers" that offer a controlled discharge before charge option for NiCads. NiMh cells don't have a memory effect so you can charge them whenever you want without discharging. That's why I use NiMh. If you do decide to use a manual discharge method make sure you don't discharge the cells too much or too fast. You will shorten the life of the battery significantly if you do.
Reply #4 on: August 20, 2014, 11:02:00 AM
If you are charging AAs I have a great charger, the LaCross BC-700.  It discharges and charges and tests AA batteries.
This is one of those "smart" chargers.  It and Low Self Discharge batteries cured my camera problems about 4 years ago.
Reply #5 on: August 20, 2014, 11:44:53 AM
I use one of those too.
Offline Tickwomp
Reply #6 on: August 21, 2014, 11:50:17 AM
Many years ago I was pretty heavily involved with 10th scale electric buggies and used 7.2v and 8.4v NiCad packs.  My primary charger had the ability to fully discharge, but in the heat of the battle, I needed to discharge several packs at once and I was using the charger to charge or top off a pack.
I soldered together about 10 single element tail light bulbs together with a battery connector.  I made several of these and they were did a good job pulling the packs down evenly without overheating them.  The talk at the time was this load was very similar to what the motors were pulling and it helped the battery packs stay matched.  I don't remember how far I would discharge, but I would I would monitor with a voltmeter and pull them off at a certain point.
Seemed to work well enough and I was still using this method when I moved up to 8th scale gas.
Tick
Mach2 Mac Mini->Amarra Mini-> Chronos Athena USB Cable->Audio Note 4.1LE DAC->24ga Ag w/WBT0101ag ICs-> Audio Note L4 Remote->24ga Ag w/WBT0102Ag ICs-> Paramounts w/MQ Nickel Opts and EML 2a3 Mesh Plates->16ga Ag Bi Wire->Klipsch RF-7 w/DeanG Mods
