No right channel after Speedball install
randuin · 3208
Offline randuin
on: August 20, 2014, 07:30:57 PM
First built the Crack, sounds beautiful. However, after installing the Speedball I have no right channel (left sounds great!). The LEDs on one of the small boards is not on and the voltage for Terminal 5 is way too high @ 170V ish
Reply #1 on: August 21, 2014, 07:11:47 AM
I would start by double checking that all the transistors are where they should be.
Often times this issue is resolved by reheating the solder joint of the MJE350 on the offending channel.
Offline randuin
Reply #2 on: August 21, 2014, 03:29:15 PM
I resoldered the points to the transistor and now the LEDs are on but Terminal 5 now has 0 voltage :(
Tested the MJE350. Voltage around 170 on 2 outer legs. 0V on the middle. solder joint looks fine. Was testing directly on the leg too. Is this blown?
« Last Edit: August 21, 2014, 03:37:58 PM by randuin »
Reply #3 on: August 21, 2014, 06:30:35 PM
Yeah, you still have flaky joints somewhere.
I'm guessing both LED's on the socket aren't yet lighting, and won't until all those joints are nice and toasty.
0V on the collector of the MJE-350 would tell us that the transistor is completely open (turned off).  Generally when these blow, they blow shut.
Offline randuin
Reply #4 on: August 22, 2014, 09:19:42 AM
Which spots would you suggest testing? The two LEDS on the socket are actually lit up.
Reply #5 on: August 22, 2014, 11:51:23 AM
Still having flaky solder joints means reheating the joints on the PC board.
Offline randuin
Reply #6 on: August 22, 2014, 04:57:03 PM
Relooking at things. It seems like the LEDs on the small boards are lit. But the LED that goes to A3 is off now.
Reply #7 on: August 22, 2014, 05:10:34 PM
Yup, flaky solder joint.
Offline randuin
Reply #8 on: August 22, 2014, 08:28:12 PM
After going through and testing what feels like everything. A socket is all good. Left board is good. Big board is good. However I'm back with the problem with the right board LEDs being off and lead 5 being 170 volts or so
EDIT: Just more info - same 170V at middle lead of the MJE350 and at the other transistor
« Last Edit: August 22, 2014, 08:46:50 PM by randuin »
Reply #9 on: August 23, 2014, 08:30:15 AM
Since you have 0V on the middle leg of the MJE350 on one test and 170V on the other test, I would still say that the center leg of the transistor needs to be reheated.
Offline randuin
Reply #10 on: August 23, 2014, 09:12:30 AM
Thanks so much for your patience but is there any simple continuity test I could do on the middle leg to try and figure this out? I feel like I've reheated this leg over and over again with no results.
Reply #11 on: August 23, 2014, 09:36:27 AM
Swap the little boards between sides and verify that the high voltage follows the board.
Also be sure there aren't solder blobs on the bottom of the board shorting out adjacent pads.
