More S.E.X. is always good
marantzfan · 2139
Offline marantzfan
on: August 24, 2014, 04:54:59 PM
Just last night I finished adding the C4S upgrade as well as the impedance switch kit to bring this build to an end.  As usual the instructions were very well written and all voltages were dead on the first power up.
The only suggestion to the manual writers is that when initialing wiring for 32 ohm, the leads coming off the right channel OPT were a very tight fit compared to every other bit of wiring in the kit.  Might want to consider adding an inch or so if you ever update the manual.
This build I decided to keep the base natural and just used Danish oil, 2 coats.  I took the chokes and PT end bell to my buffer and shined them up a little (not looking for mirror finish) before clear coating.
Pics soon...
BeePre, Paramounts 1.1, Eros, Thorens TD-124/AudioMods Tonearm/Ortofon 2M Black, IFI Micro Idsd, HQPlayer,  Altec 604-8G Duplex/620 Cabinets/Markwart Crossovers
S.E.X. 2.1, AKG K701
