Signal negative to chassis ground?
ALL212 · 2180
Offline ALL212
on: August 27, 2014, 01:55:15 AM
I'm slowly building up my S.E.X....hmmm, probably a better way to phrase that but...
I find the signal ground (input RCA ground tab) shorted to chassis ground as well as the STP shield.  At first I thought I messed up but the jumper from 12 to 13 is where this connection is made.
All is well?  Or did I goof up somewhere?
Aaron Luebke
Reply #1 on: August 27, 2014, 02:11:19 AM
You are fine.  This "defines" ground.  The signal will move positive and negative relative to ground.
Reply #2 on: August 27, 2014, 05:11:43 AM
Yep thats normal, and the output side is grounded by a jumper from 23U to the headphone socket.
