stereomour power supply
ee · 3089
Offline ee
on: August 29, 2014, 03:12:58 AM
On the Stereomour power supply pcb there is the (#1) 100 uf cap then the (#2) 220 uf cap next to it on the rear side of pcb. Can I substitute a 200 uf cap for it without harm. If I get a tight tolerance cap +/- 5% it seems I should fall within design tolerances but would appreciate the words "ok"  for "no way dude I said 220 uf" before I move ahead. Thanks
Eric
Bottlehead Stereomour 2a3
Fostex FE206En in Vulcan (BIB BLH)
VPI Scout 1.1 with classic platter
Lyra Delos
Manley Chinook phono pre
Creek Destiny 2 CD
Audio Art Power Cables
Reply #1 on: August 29, 2014, 05:11:47 AM
Build it stock first. If you want to change it down the road, you will have a baseline to compare your changes to.
