6080 not lighting
purpleymok · 4437
Offline purpleymok
on: September 02, 2014, 02:22:45 PM
I've reached the end of my troubleshooting abilities and could use some help - I built a stock Crack and ran through initial resistance and voltage checks which were all within tolerance, then immediately added the Speedball - I'm now seeing the following symptoms:
1. 6080 not lighting
2. LEDs on the "big" speedball board aren't lighting (all others are)
3. some voltages are off:
    terminal 7: 0V (expected per manual: 100)
    terminal 9: 0V (expected per manual: 100)
    terminal 13: 210V (expected per manual: 185)
Any suggestions?  Thanks!
Reply #1 on: September 02, 2014, 02:43:21 PM
Is the 12AU7 glowing?
It would be odd for the 12AU7 to glow and not the 6080, but it's possible.
Offline purpleymok
Reply #2 on: September 02, 2014, 02:45:34 PM
Yes, the 12AU7 glows.
Edit: or at least the middle "rods" (heaters/cathodes?) of it do, assuming that's all that's expected.
« Last Edit: September 02, 2014, 03:14:08 PM by purpleymok »
Reply #3 on: September 02, 2014, 05:53:48 PM
That's so very odd.
The twisted pair of red/black wires that leave power transformer terminals 4 and 5 are what make the tubes glow, and they stop off at B7/B8 first, then go up to A4,5/A9.
If the 6080 isn't lighting, maybe there's a loose wire on the octal socket at B7/B8.  It's also possible that a pin isn't making good contact.
In either case, there's no reason to focus on the Speedball boards when troubleshooting this issue for the moment.
Reply #4 on: September 02, 2014, 05:59:40 PM
Also possible the socket is rotated so the wrong pins are connected. Or the heater is dead (check DCR pins B7 to pin B8, with 12AU7 removed).
Offline purpleymok
Reply #5 on: September 02, 2014, 07:25:30 PM
With 12AU7 removed and 6080 in, resistance between B7 and B8 is reading as 0.  So I desoldered transfo terminal 5 and it looks like transformer 5 is going to ground without anything connected to that terminal - is that expected?
I buffed the pins and they seem to be making good contact as far as I can tell.  As far as I know the orientation and heater supply seem correct - here are some pictures:
Heater wiring: transformer 4/5 -> B7/B8 (-> A4,5/A9):
http://i.imgur.com/PDbc3Qk.jpg
Socket orientation:
http://i.imgur.com/AgRGKqQ.jpg
Reply #6 on: September 03, 2014, 05:19:37 AM
Power transformer terminals 4 and 5 have a red and black twisted pair of wires attached to them that run to B7/B8.
PB
Reply #7 on: September 03, 2014, 05:28:53 AM
Suggestion, try measuring the resistance of the heater pins on the tube itself, just incase its broken internally.
Offline purpleymok
Reply #8 on: September 03, 2014, 07:47:00 AM
Yep - they definitely have good connections.  I verified good electrical connections between transformer terminal 4->B8 socket, terminal 5->B7 socket.
I just meant that transformer terminal 5 seems to be grounded even when it didn't have anything connected to it, which I didn't expect since pin 4 is also tied to ground in the directions and it seems like that would short things... but maybe that's expected?
With the tube disconnected?  The resistance between the heater pins (pins 7/8) is reading as infinite.
« Last Edit: September 03, 2014, 07:50:26 AM by purpleymok »
Reply #9 on: September 03, 2014, 08:00:23 AM
The winding inside the power transformer between those terminals is just a long piece of wire wrapped around the bobbin, so this isn't too surprising.
That's an open filament, a different 6080 is in order.  You can also try reheating the actual pins themselves on the tube base to reflow the solder joints in pins 7 and 8, there may just be a loose connection that was never properly soldered from the factory.
Offline purpleymok
Reply #10 on: September 03, 2014, 08:10:40 AM
I reheated pins 7/8 but there still seems to be no connection between them.  That's assumedly the issue then.
It's the 6080 that came with the kit.  I'll see if I can get another one somewhere.  Thanks for all the help!
Reply #11 on: September 03, 2014, 09:34:04 AM
Yes if pins 7 and 8 on the 6080 read open it's a bad tube. We are happy to send a replacement. Best way to get the proper info to us for a speedy delivery is to email replacement parts at bottlehead dot com.
Offline purpleymok
Reply #12 on: September 10, 2014, 04:44:14 PM
With the replacement tube everything is working great.  Thanks!
