Paramount? Maybe.... what'cha think?
rebbi · 10490
Offline rebbi
on: September 06, 2014, 05:30:45 PM
Hi, Gang,
Been a long time since my last post here! I built a Seduction kit a few years ago and have been very happy with it.
So: I have been happily using my Reference 3A De Capo stand-mounts with a Manley Shrimp preamp and a pair of Manley Mahi mono-blocks (in 20 wpc triode mode exclusively). My room is approx. 16' x 11' with an 8' ceiling. The De Capo's are a straightforward 8 ohm load and are 92 db sensitive. They were, by all accounts, voiced with SET amps in mind.
The other day, over on Audio Asylum, someone said, "If you really want to hear your De Capo's sing, you need to hear them with a SET amp." Hence, my interest in the Paramount kit.
Anybody got opinions about this pairing? And since I'd need a preamp, how do you think the Shrimp would pair with the Paramount? And, how do you think the Paramount compares to commercially available offerings from, say, Antique Sound Labs or Decware?
I breathlessly await your wisdom.   ;D
Reply #1 on: September 06, 2014, 06:17:59 PM
Your room size and speaker should work quite well on Paramounts (stick to 300B's).
For making an informed purchasing decision, it would be worthwhile to read up on directly heated triodes vs. everything else.
Being a Bottlehead employee, I will bow out to making further comparisons.
Offline tsingle999
Reply #2 on: September 07, 2014, 06:33:51 AM
There is no comparison between a Decware SET and a Bottlehead SET. The SEX amp is way better than the Decware when i had both. The dht BH ampS are better than the sex amp. Just my opinion.
Bottlehead Stat headphone amp
Offline wullymc
Reply #3 on: September 07, 2014, 06:50:31 AM
I can't say much in terms of the different companies you are trying to prepare.  What i can tell you is that I have Paramounts on order and in no way feeling buyers remorse.  I have completed a Quickie and Crack kits and find them excellent.
What I can also tell you is that you won't find a better community to help you than here.  Everyone employed at Bottlehead I have had the pleasure of talking with has been extremely helpful, and professional.  Anytime that I have had any questions they were responses the same day and helped me getting my stuff working.  I know that when I need their help they will be there for me.
Good luck in your decision.  All the best...Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Offline Brent
Reply #4 on: September 07, 2014, 11:33:32 AM
It looks like the Shrimp's gain (11.8 dB) and output impedance (50 Ohms) would match well electrically with the Paramounts (input impedance 249KOhms and input sensitivity 1.56v for full power).
I use my Paramounts with a Smash or sometimes a passive volume controller to switch things up.  Smash, which has a little less gain than the Shrimp, works out a bit better with my speakers, which are about 90 dB Alpair 10p Pensils.  All of which is to say (again) that the Paramounts should work out alright in your system gain wise based on my experience and listening habits.
I haven't heard the Shrimp.  As to the Paramounts, though, I can't think of any amplifier I would rather own. Whatever else happens, I've got that amplifier problem handled.
Offline Paully
Reply #5 on: September 07, 2014, 05:00:18 PM
Didn't Grainger have 2a3 Paramours running his Triangle speakers (similar sensitivity).  Thought I heard that pairing and it was wonderful.  I would imagine Paramount 300B's would be more so.
But I am biased (I love making that pun) as we all are.  There are simply no better kits out there for quality sound and quality manuals than Bottlehead.  That I do believe.  If I had it to do over again I wouldn't hesitate to buy the Paramounts.
Other questions, sorry, don't have an opinion!
Offline rebbi
Reply #6 on: September 08, 2014, 03:19:15 PM
You know, a certain, very active Forum participant  ;D PM'ed me to say that he thinks that the Stereoamour would actually be a great match for the De Capo's. What do the rest of you think?
Reply #7 on: September 08, 2014, 03:29:51 PM
I think the extra power and fidelity from the Paramounts would be a better match for the De Capos.
Reply #8 on: September 08, 2014, 04:20:24 PM
Unfortunately, rooms, ears, and musical taste vary widely.
I usually recommend 10 watts for a 92dB speaker. This comes from analysis of several years worth of Stereopile speaker reviews, which list the magazines recommended minimum power - this is enough to get 102dB peaks, and if you allow both speakers to run you get 105dB which is the THX home=theater standard.
It is my estimate that the above combination will satisfy "most audiophiles most of the time". I also estimate that 6dB less (1/4 the power) will "usually satisfy 50% of audiophiles" (and 90% of their wives, I'm guessing, since women on average have more sensitive hearing).
None of the above allows for the soft clipping of no-feedback triode amps. Some people are more sensitive to this than others, and musical/recording style plays a huge role, so I don't like to put a number on it. But there is some truth to the reputation that SET watts are bigger than solid-state watts. (this paragraph added)
« Last Edit: September 08, 2014, 06:33:18 PM by Paul Joppa »
Offline Maynard
Reply #9 on: September 08, 2014, 05:44:01 PM
How about a 96db speaker? How many watts would you recommend then?
Reply #10 on: September 08, 2014, 06:28:28 PM
96dB = 4 watts.
The calculation is the power (in dB re: 1 watt) plus the sensitivity (dB/w/m) equals 102dB.
Power in dB re 1 watt is 10*log10(watts): 2 watts is 3dB, 4 watts is 6dB, 8 watts is 9dB, etc...
Offline Demsy
Reply #11 on: September 08, 2014, 08:41:46 PM
My room is almost the same size as yours, Rebbi. At the moment I'm using a Troels Gravesen DTQWT horn loudspeakers, 95db sensitive, with 2A3 Paramounts. For my music listening, it's more than enough power for jazz, classical, pop etc. I have a 105db speakers coming, I am sure 3.5w is plenty.
But one thing to look at is the impedance of the speakers, with too high rising impedance, you'll then need more power to drive them, though.
Offline rebbi
Reply #12 on: September 09, 2014, 02:48:29 AM
Everybody,
First of all, thanks for the interesting and very helpful responses.
I tend to think that the Paramours would do it for me for a couple of reasons.
First, although I occasionally crank my system, I don't like listening at "rock concert levels." (Call it paranoia about preserving my middle-aged ears.) I tend to like to listen "into" the music, rather than being battered by it.   ;)
Additionally, Reference 3A, maker of the De Capo, also imports the Antique Sound Labs line of tube electronics, and they say that the ASL AQ 1005 DT integrated was pretty much designed with the De Capo's in mind. Here are the relevant specs on that ASL amp...
TECHNICAL SPECIFICATIONS
Output Power 8WPC
Frequency responsible  at 1 W   18Hz - 19KHz
Frequency responsible at full power   33Hz - 18KHz
Distortion at 1W   0.7%
Distortion at full power   8%
S/N Ratio at full power/ Noise level mV   80 dB /<1.2mV
S/N Ratio at 1Watt / 8Ohms   67 dB
Input impedance   100K
Output Impedance   4, 8, 16 Ohm
Input sensitive   1V
Power request   250W
So, that being the case, the Paramour would seem to be a good match, no?
Reply #13 on: September 09, 2014, 04:57:43 AM
Yeah, the Paramount will spec out similarly to that amp, though I suspect the bandwidth will be quite a bit higher (we don't generally bother to measure bandwidth at anything other than full power), and the noise level we have measured is a bit lower than 1.2mV (you don't notice on your De Capos).
Offline rebbi
Reply #14 on: September 11, 2014, 08:48:40 AM
I know it's a little silly asking this question on this forum, but how do you think the Paramounts stack up against the Coincident Dynamo 34 SE?
http://www.coincidentspeaker.com/mpsip_amps.html
