Left channel cuts out [solved]
jt · 2121
Offline jt
on: September 20, 2014, 10:49:50 PM
The left channel on my crack cuts out after about 10 minutes. Swapped tubes and get the same result. Voltage check is ok. How can I troubleshoot this?
Thanks, Jay.
« Last Edit: September 24, 2014, 05:11:52 PM by Caucasian Blackplate »
Offline NightFlight
Reply #1 on: September 21, 2014, 06:19:46 AM
To start, swap the input RCA cables.
Reply #2 on: September 21, 2014, 06:25:23 AM
Visually inpect every solder joint to see if you missed soldering one. Cutting out after a few minutes is usually something that happens because something expanded as the amp warmed up and shifted, losing contact.
If everything looks good, redo your voltages while in the amp is warm and post any big deviations from the figures in the manual. If you can find what is getting disconnected we can isolate the problem.
« Last Edit: September 22, 2014, 11:45:47 AM by Doc B. »
Offline jt
Reply #3 on: September 22, 2014, 11:28:35 AM
I figured Doc was right about heat expansion so I re-flowed all the socket connections and terminal strip connections.
Fixed the problem.
Thanks for the help!
Jay.
