Did I blow it? [solved]
danox574 · 7531
Reply #15 on: September 28, 2014, 07:30:02 PM
I'm glad to hear that things snapped into place.
Give it 20-50 hours to settle in, then slap that upgrade back in and you should be good to go.
Offline danox574
Reply #16 on: September 29, 2014, 04:01:06 AM
Sounds good.  Do you think a solder joint issue on the 4007s was likely to be the issue, or may I have bumped something else when I was working in there?
Reply #17 on: September 29, 2014, 05:00:07 AM
I think you bumped into something else.
The UF4007's make the high voltage, and you had no low voltage.
You likely nudged a loose connection on the two fatter diodes that make ~12V, then restored operation to the preamp.
