Left channel went out
dingwersen · 3501
Offline dingwersen
on: October 07, 2014, 08:35:58 PM
I Built my Stereomour about 3 years ago, no problems with the build, followed the directions step by step and with a little beginners luck (and some great direction) had a functioning amp. The only "problem" that I could see was a dead spot in the volume pot. This was a bit hi of my normal listening range so I chose to ignore it. I have been driving a pair of old Klipch Heresy's and my rather pedestrian ears have been quite happy.
One day I went for a listen and there was no sound from the left channel. An examination led me to find that the left tube had a foggy discoloration on the inside bottom, near the Bak-o-lite base of the tube. I figured the tube had "worn out" so I bought a new pair of the same brand and plugged them in and still no sound from the left channel.
I am a bit stumped, I'm not an "electronics guy" per-see, but I'm pretty handy and am fine with doing my own research, if someone could just point me in the right direction.
Thanks in advance,
Dan
Reply #1 on: October 08, 2014, 12:54:05 AM
The first step is to take the resistance measurements.  Take the tubes out.  Post any that are greater than +/- 15% from the manual.
If the resistance is good move on to the voltage measurements.  Tubes in.  Again post those outside the 15% range.
Reply #2 on: October 08, 2014, 06:30:07 AM
If there was a white fog at the bottom, the tube lost its vacuum and is indeed dead.
If you're still missing a channel, I would start with a voltage check.
Offline dingwersen
Reply #3 on: October 08, 2014, 10:07:55 AM
Thanks to both of you.
I am going to try the voltage test as suggested.
I recently moved and have yet to come across my manual. I may have to get another. I'll post back in a week or two once I have done a bit more reading and testing.
Thanks again,
Dan
