Combining two Cracks
modestmeowth · 5162
Online Paul Joppa
Reply #15 on: October 20, 2014, 02:05:06 PM
Dual concentric pots also exist. The only ones I found easily are 500K but should work. The inner shaft is small and goes through the larger outer shaft, allowing each section to be adjusted independently. They are available from many guitar part vendors, along with suitable knobs. Fits in place of the current control, wired up the same. I could not quickly verify that they have an audio (logarithmic) taper but even if they don't some faking can be done with a couple resistors.
Just another option.
Offline modestmeowth
Reply #16 on: October 21, 2014, 07:34:12 AM
Thank you all!! How hard is it to wire a dual cencentric pot?
Reply #17 on: October 21, 2014, 08:02:53 AM
The lugs are much the same as the stock pot.  There are actually 2 pots stacked on each other.  So is the stock pot but it only has one shaft.
Reply #18 on: October 21, 2014, 08:56:27 AM
As the quote that you replied to states, it drops into the same hole as the stock pot, and wires up the same. (But you'll need a different set of knobs)
