how hot is too hot!
howzz1854 · 2715
Offline howzz1854
on: October 22, 2014, 07:56:40 PM
so thanks for all you guys' help. my first self built amp (crack) is now fully working.
but i notice the amp gets really hot. i know the tube is supose to get hot, but when i touch the aluminum plate, it's feeling pretty hot too. so i am just wondering how how is too hot. should i stick a couple aluminum heatsinks underneath? on top?
Xonar Essence STX >> Schiit Bifrost >> Bottlehead Crack (TS 7236/RCA 5963) >> HD800s
Reply #1 on: October 22, 2014, 08:30:05 PM
It's fine, tube gear just gets hot. Just make sure you have the rubber feet on the base so that it sits above the surface it's on and air can flow in from underneath.
Offline howzz1854
Reply #2 on: October 22, 2014, 09:05:59 PM
cool... i was going to wait until i stain the wood, but i'll put those feet on now. thanks!
Reply #3 on: October 23, 2014, 02:18:17 AM
That is FAQ #3:
http://bottlehead.com/smf/index.php?topic=2408.0
Some were cut off in the last update of the site.  I have found 2 more to add.
Offline kgoss
Reply #4 on: October 23, 2014, 04:07:11 AM
You could put a book under each end to raise it until you are ready to finish the base. Whatever you do make sure the amp is stable and won't fall.  Air flow under the base is critical for proper cooling.
Ken Goss
