S.E.X. amp and turntable
tristan · 10181
Offline tristan
on: May 09, 2010, 04:03:51 AM
Hi all,
I recently bought a S.E.X. amp kit (it's on order, yet to arrive), and I'm sorry if this is a very simple question, but I wanted to know if I need a preamp to be able to use my turntable with the S.E.X. amp or can I use it without a preamp? Or will I get no/very little sound? If I need a preamp then I'll order a Seduction kit... I just am unsure as whether a preamp for my turntable is necessary or not...
In case it matters, the turntable is an NAD 533 with a Goldring Electra cartridge. The amplifier I am replacing with the S.E.X. amp is a Pioneer SA-5300 which has a Phono input, which I'm guessing may have some kind of simple preamp built-in? Anyway, I'll be very grateful for any help or advice people can offer!
thanks in advance,
Tristan.
Offline Paully
Reply #1 on: May 09, 2010, 04:36:08 AM
Some terminology; there is a preamp which is also called a line stage preamp (Foreplay III) and there is a phono preamp (Seduction / Eros).  To be able to play your turntable you are going to need a phono preamp (Seduction / Eros) to boost the tiny signal coming off of the turntable.  Whether you need an additional step-up transformer is determined by the output of your cartridge.  Anything above say 1.5- 2.0mv you shouldn't.  But that is ball park and others may disagree.  To be able to switch between inputs (CD / Phono Preamp / SACD player / Etc...) you need a line stage preamp.  Here is how it goes:
Turntable feeds a
Phono preamp which feeds a
Line stage preamp (not necessary if you only use one source and have a volume control on the amp) which feeds an
Amplifier which feeds your
Speakers
If you are using a CD player
CD player feeds a
Line stage preamp (not necessary if you only use one source and have a volume control on the amp or CD player and the phono preamp is obviously bypassed) which feeds an
Speakers
Reply #2 on: May 09, 2010, 05:18:25 AM
I checked the Goldring Electra and it is a Moving Magnet (MM) cartridge.  99.9% of MM cartridges will not need a step up device with a Seduction or Eros and yours is fine at 5mV output.  You can dedicate the table/cartridge to the SEX amp or if you also listen to CDs you can purchase a simple switcher from Radio Shack.  I believe that item is still sold there.
Offline JC
Reply #3 on: May 09, 2010, 05:56:18 AM
You will need a phone pre-amp for a couple of reasons.  The first reason is that magnetic phono cartridges put out only a very tiny signal, and must have considerable Voltage amplification applied before the signal is at an appropriate level to feed a line-level input.
The second reason has to do with the RIAA equalization used when the record was cut in the first place.  The recording industry settled on a standard equalization some decades ago for the sake of getting more music on a given size of record.  Using no equalization would have resulted in very few selections on one LP, because bass frequencies take up a lot of real estate.  So, a standard EQ was established that reduced the bass frequencies relative to higher frequencies, allowing the grooves to be much more tightly spaced next to one another.
The other part of the standard provides for correction of the recorded EQ during playback.  To meet the standard, the phono preamp must have built-in equalization that is essentially just the opposite of the EQ used when the record is first cut.   To over simplify, think of turning the "bass" control down when the recording is made then back up when the recording is played back.  This is essentially what the RIAA equalization standard does.
So, in order to play back a record with RIAA equalization, you need something that is designed for the purpose.  The SEX (and other amps with line level inputs) do not have that facility built-in and a phono preamp is necessary.
If you want to try a simple experiment, plug the output of your table into a "tape", "line", or "aux" input on your current rig.  You should find that not only is the volume greatly reduced, but the bass will be pretty much non-existent.
BTW, during the hey-day of Disco in the 70's, club DJs had access to "disco cuts" of the hits of the day.  These consisted of a 12" record with only one song cut on each side, to allow for more room to record the bass characteristic of the genre.  Prior even to that, radio stations, particularly if they played classical and/or orchestral music, often had records much larger than the 12" diameter, again with the idea that more real estate allowed for a higher fidelity recording.  So, there have been several "standards" over the years.  But, the standard for home use has been the RIAA since, I believe, the 1940s.
So, yes, you will need a Seduction or an Eros, or some other kind of phone preamp to go with your SEX.  To get started with, though, if your current rig has a "line out" or "tape out", you could use that to feed the SEX amp.  This would allow you to use the "phono" preamp you already have to play records while you decide.
Jim C.
Offline tristan
Reply #4 on: May 12, 2010, 03:50:24 AM
Thanks all, that answered my question and more! Pretty much confirmed what I thought. I've now ordered the Seduction and I'll see how it goes!
Thanks again!
Tristan.
