Binding Post washers?
vpeele · 2953
Offline vpeele
on: October 24, 2014, 10:26:28 AM
Hi All, On Page 38 of the pdf paramount 300b Binding Post construction I have 8 washers leftover. Where do they go and in what order? Thanks so much!, van
Reply #1 on: October 24, 2014, 10:50:20 AM
I'm deleting my snarky response....
The binding posts are a different design from what is shown in the manual. You probably want a flat washer above the top insulator and below the bottom insulator. The top one you will want to make sure that you have electrical connectivity to the post when using spades or bare wire. The one below just to be a flat surface to tighen the nut. You probably don't need all the lockwashers, and one nut should suffice.
