paramount resistance check- help
vpeele · 4366
Offline vpeele
on: October 27, 2014, 05:18:50 AM
Hi All, I think I have big resistance problems. Please help.
       left amp 300b                     right amp  300b              pdf manual
terminals
1.    reading keeps raising          reading keeps raising          *
5.    .999   meterset@2k             01.0  meterset@200k       1k
6.    1.113 meterset@2k            1.120  meterset@2k          1118
7.    .248  meterset@2m            .248   meterset@2m          249k
9.    reading jumps around          297   meterset@2m          124k
10.  0 meterset@2m                  .000   meterset@2m           0
11.  no reading  @ any setting     no reading                        3.0
12.  no reading                           no reading                        5.6m
13.  0                                         0                                      0
14.  no reading                           no reading                        9.2m
15.  no reading                           no reading                        15m
16.  no reading                            reading increases               *
17.  0                                         0                                      0
18.  0                                         0                                      0
19. .300                                     .297 meterset@2m            128k
20. .248 meterset@2m                .248 meterset@2m            249k
Tubes  left chan                        right chan
300b
A1.   1.012  meterset@2k            1.018  meterset@2k           1027    300b
A2.   no reading                            no reading                           *
A3.   249  meterset@2m             .248   meterset@2m              249
A4.   1.012 meterset@2k            1.018  meterset@2k              1028
B1.   0                                        0                                         0
B2.   9.84  meterset@20k            9.71 meterset@20k              8.2k
B3.  .248  meterset@2m             .248 meterset@2m               249k
B4.  .299 meterset@2m              .297  meterset@2m              130k
B5.   0                                        0                                        0
B6.   .299  meterset@2m            .316  meterset@2m              177k
B7.   .232  meterset@2k              229  meterset@2k               220
B8.   no reading                          no reading                           *
B9.   0                                         0                                       *
Thanks for any help!, vpeele
Reply #1 on: October 27, 2014, 09:25:06 AM
terminals
B9.   0                                         0                                       *
This is a list of terminals that are actually different than what the manual specifies.
0 on B9 is OK, you should see about the same thing on B1.
The B6 reading is OK, there are enough complex components in there that something much higher than 0 is ok.
The B4 reading is disturbing.  There should be a 300K resistor from OB to -reg, is it present?  What's your resistance reading from -reg to ground?
19 and B4 are wired together.
9 is also wired to 19/B4.
Offline vpeele
Reply #2 on: October 28, 2014, 10:37:51 AM
Hello PB, 300k (or,bk,y,go)  is installed at OB to -reg. Resistance reading from -reg to ground is 0.
{The 300k resistor reads  300 @ metersetting 2m.}
Yes 19 and B4 are wired together. Yes 9 is wired to 19/B4.
I will keep inspecting all solder points and connections.
Thanks for your help,
vpeele
Reply #3 on: October 29, 2014, 07:47:51 AM
Go ahead and try the voltage checks.
