Paramount voltage concerns **SOLVED!!**
wullymc · 16113
Reply #30 on: November 11, 2014, 03:16:06 PM
Dave,
When you check  continuity from the newly installed boards to the terminals or tube pins try checking from a component lead that is attached to the input/output/ground solder tab to the metal of the terminal or tube pin.  Don't check from solder to solder.  That can give you a false sense of security with the solder joints.
I have been bit in the butt by just this.  So now I "ring out" from a component to component.
Good luck!
Offline wullymc
Reply #31 on: November 12, 2014, 04:15:26 PM
Thanks to everyone that contributed to this thread.
I am very happy to report that everything is working now!  I have about 3 hours on both amps and everything is great.  I had a problem with a FFFFFFF sound when I turned on the left one but that disappeared after 3 turn ons.  I don't know if it was just something that needed to burn in a little bit?  I don't know.
Anyway, thanks again for your patience with me!  I am so happy!
Take care.  Wishing everyone well.
Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Reply #32 on: November 14, 2014, 07:24:29 AM
There are some warm up noises with the Paramount, which shouldn't be of concern.  There will be a little rustling usually, and actually a funny chirp that happens when the 431 regulator begins to operate.
