Fuses
Doc B. · 1931
on: November 20, 2014, 08:39:55 AM
Apparently a recent shipment of 1 Amp fuses had some 10 Amp fuses mixed in by mistake. If you have received a 10 amp fuse in error your amp will work with it, but it won't be very well protected from any wiring errors or component failures. The fuses that are incorrect are marked 10A rather than 1A on one of the metal ends, and thus should be easily identified. If you got a 10A fuse in error and would like a replacement we are happy to send one to you.  Email [email protected]. If you are outside the States it might be quicker and easier to pick a 1A fuse up at a local hardware store.
« Last Edit: November 20, 2014, 08:49:50 AM by Doc B. »
